Printrbot Talk Forum • View topic - First Print, almost great!
Postby Tdeagan » 2013-Feb-Mon-12-Feb
New Printrbot Plus. 32 hours build time from box opening to this print (a couple of hideously failed attempts preceded this.)
After many hours of extruder grief, I managed to get a legit first print. Getting the filament to feed without stripping was a mess and I had to do a _lot_ of hob bolt cleaning.
Here's the model I started with (simple maker-mark stamp I've made for my leather working):
Here's the print:
There is some gapping between the perimeter and infill and a weird jog that is on the outside top right (and seems to be on the outside top right of the internal circle.)
The bottom layer is a bit flatter than I'd like.
Lots of tuning awaits me!
--Tim
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Re: First Print, almost great!
Postby Tdeagan » 2013-Mar-Wed-14-Mar
Tuning largely complete!
Primary problem was that my X axis motor mounting was trapezoidal rather than square. See Step 142 in the PB+ assembly instructions (sorry, system won't let me add an actual link offsite). The bolt attaching 220 to 232 needed a nut INSIDE to keep the belt from pulling the motor into the frame, rather than OUTSIDE. My motor was rubbing against the frame and causing the equivalent response to backlash.
--Tim
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby Marcus » 2013-Mar-Wed-15-Mar
Awesome, well done!
Marcus
Postby artem » 2013-Mar-Wed-15-Mar
That looks really good!
artem
Postby plexus » 2013-Mar-Wed-15-Mar
Very nice. you need a little more infill perimeter overlap. ;)
Postby noyart » 2013-Mar-Fri-17-Mar
wow how did u set up ur printer so it printed this good? :O
Im waiting for my spur gears from shapeways, would love to know how and what you did to make your prints this good :O did you fallow that calibrate with slicer tutorial or something else? :)
noyart
