Thew wrote:BTW Im also a HAM (KD7VUG)
lwalkera wrote:I said this in another thread, but if you don't mind lack of a backlight, you can disable it by desoldiering the solder jumper on the back of the LCD board to the right of the pin headers. If not, you could probably replace the dropper resistor that's there with the correct value for 5V. The IC for the LCD appears to be able to work with either 5 or 3.3 volts, it's only the dropper resistor that appears to be different between the two models.
(I have a ham license, KI6APQ, but never really did anything with it. Hoping to get more into it with http://www.kickstarter.com/projects/mos ... r-platform .)
Tdeagan wrote:Is that the R7 shown in this pic?
