by RetireeJay » 2018-Sep-Tue-10-Sep
I never knew Printrbot made a CoreXY printer! But evidently they did. No one on this forum has ever discussed the Model 3 before. But there's a person going by the Thingiverse handle of "ururk" who has one, and he/she designed some improvement parts that are posted there; maybe you can find a way to get in touch with that person and see if they can point you to resources for building and commissioning the printer.
https://www.thingiverse.com/thing:2772473
