Wiring up a LED power supply for heated bed
Postby inertianinja » 2018-Aug-Sun-08-Aug
My original ATX power supply died, so I need a replacement.
I have seen a lot of recommendations for using a LED power supply like this: https://www.amazon.com/eTopxizu-Univers ... 00D7CWSCG/
I'd like to wire up one of the 6-pin molex connectors that would connect to the stock board.
Does anyone have a guide for how to wire this up properly? I have a basic idea of what to do, but since it's power I'd rather not leave anything to chance.
inertianinja
Re: Wiring up a LED power supply for heated bed
Postby novice » 2018-Aug-Sun-08-Aug
I occasionally move my printers so an xtra molex was added outside the printer to facilitate separation.
Another view under the printer.
Found the connectors on Amazon. This style of power supply has a pot up front to vary output voltage, so you might consider a digital display for that. There is a plethora of printed power supply front covers on thingiverse.
Postby inertianinja » 2018-Aug-Sun-09-Aug
novice wrote:I occasionally move my printers so an xtra molex was added outside the printer to facilitate separation.
So all six connectors on the power supply are used?
https://images-na.ssl-images-amazon.com ... L1000_.jpg
inertianinja
Postby novice » 2018-Aug-Sun-09-Aug
Yes, if only to spread the load. The terminals are there, you may as well utilize them. Believe if one were to check, continuity exists between all of the power supply's + connections. The same with the - connectors. I then piggyback one set of the screw terminal 12v leads for a panel mounted voltage meter. I suppose one could use two pairs of terminals for printer power and the third for meter and it would be ok.
Sorry I thought you originally sought clarification at the printer terminal, not the power supply.
Postby inertianinja » 2018-Aug-Sun-16-Aug
novice wrote:Yes, if only to spread the load. The terminals are there, you may as well utilize them. Believe if one were to check, continuity exists between all of the power supply's + connections. The same with the - connectors. I then piggyback one set of the screw terminal 12v leads for a panel mounted voltage meter. I suppose one could use two pairs of terminals for printer power and the third for meter and it would be ok.
Thank you...so, if I'm understanding correctly, I would take one of those 6-pin molex connectors from a power supply, and connect the 3 black and 3 yellow to the corresponding V- and V+ lines, and that's it?
(obvs i'd need a power cord for the AC L/N/GND)
inertianinja
Postby novice » 2018-Aug-Sun-21-Aug
Is the molex harness something you've clipped from the old ATX power supply? Not sure how yellow wires have entered into this discussion.
In the example photos posted previously red is + and black is -, you should be able to see connector orientation on an F series board in photo molex002.jpg
Postby inertianinja » 2018-Aug-Tue-06-Aug
novice wrote:Is the molex harness something you've clipped from the old ATX power supply? Not sure how yellow wires have entered into this discussion.
sorry, should have been clearer. i have a RevF printrboard w/ the 6-pin molex connector.
The 6-pin PCIE cables that come with modular power supplies - my understanding of the pinout is 6+/6-; some of the cables I have include 3 yellow wires (12V as far as I know) and 3 black wires.
Yours look like red and black instead; i hadn't seen 6-pins that use red, but same thing.
inertianinja
Postby RetireeJay » 2018-Aug-Tue-15-Aug
Yes, the standard color code for PC power supplies has black for ground, red for +5V, and yellow for +12V. Often other power supplies will use black for ground and red for whatever positive voltage they are providing.
