by RetireeJay » 2018-Jun-Mon-09-Jun
The Printrboard only uses 12V from the power supply. It creates lower voltages on-board as needed. The correct cable to use from an ATX power supply has only yellow and black wires, for +12V and ground respectively. There are many cables coming out of an ATX supply, but you can ignore the rest of them. Some printer owners use other types of supply (laptop brick, "LED" supply, etc.) The bottom line is you need 12V. When running a heated bed, you need to have approx 350 watt (or about 20 amp) capability on the 12V supply).
