Drill Bit Holder
Drill Bit Holder
Postby ktfergus » 2018-May-Fri-19-May
I’m a big fan of storing tools/pens/anything in old coffee mugs. I have at least one or two on just about every work surface in my shop. I printed this drill bit holder a few months ago & figured I might as well post it, just in case anyone else finds it useful…
It will hold a hex shank set like these up to 1/4".
I also listed the decimal equivalent for each bit & the approximate size needed when I drill pilot holes to tap various sized threads. I also left the center open to store other tools/pens/etc.
Here it is in action:
-Kelly
ktfergus
Drill Bit Holder
Re: Drill Bit Holder
Postby Jack Crow » 2018-May-Fri-21-May
Boss,
I like how you think.
Very slick idea.
Impressive.
Jack Crow
Jack Crow
Return to Showcase!
