Leftover "3mm" filament [GONE]
Postby RetireeJay » 2018-May-Tue-20-May
I've gone over to the dark side, using 1.75mm filament now, so I have some unused 3mm filament available. I'll give it to the first person who asks for all of it, just pay for shipping.
1) Unopened Taulman PLA, 1kg Through the plastic wrap, it has a silvery color (but maybe clear??)
2) Unused T-Glase (PETT), 1lb, clear Not plastic wrapped, but still inside its expanded black waffle belt.
3) Unopened Taulman 645 nylon, 1lb, "natural" white (in sealed bag with desiccant - keep nylon dry!)
4) Partially used NinjaFlex SemiFlex, approx .75 lb, white.
5) Partially used T-Glase (PETT), approx .75lb, clear.
The deal is all or nothing; if you have no use for a particular material then it's up to you to decide what to do with it.
EDIT: Found a taker.
Re: Leftover "3mm" filament
Postby Mooselake » 2018-May-Thu-09-May
Does this mean you're abandoning your plus? Don't you have a simple, too?
I'd jump on this, but despite planning to put the 3mm wades back on my plus the geared extruder/Ubis HF is working too well. I've got probably 10kg of 3mm in the hermetically sealed storage box so at this rate I'm covered until, well, probably the heat-death of the universe. It doesn't help that I've only fired up the Printrbot once or twice in the last year...
Postby RetireeJay » 2018-May-Thu-10-May
Actually, I never had a Simple. And yes, I'm abandoning the Plus. There's not room in my setup for two printers.
Return to Selling
