What kind of hardware (screws n bolts) does the simple metal
Postby Flordonwrath » 2018-Apr-Sat-06-Apr
Flordonwrath
Re: What kind of hardware (screws n bolts) does the simple m
Postby RetireeJay » 2018-Apr-Sat-07-Apr
You can google "Printrbot simple metal BOM" and find the Bill of Materials easily. It lists all the parts you should have.
And you can go to Printrbot.com and pretty easily find the instructions for assembling the Printrbot Simple Metal Kit. A PDF version is here: https://drive.google.com/file/d/0B9oj0J-4qhdjMkNKbDFrcjI5SW8/view
Postby Flordonwrath » 2018-Apr-Sat-08-Apr
RetireeJay wrote:You can google "Printrbot simple metal BOM" and find the Bill of Materials easily. It lists all the parts you should have.
Thank you very much, but right before seeing this and setting up my tax power supply for the second time just fried my printboard! I'm so upset, I was getting so close to having this thing dialed in and going great!
Sent from my SM-G950U using Tapatalk
Flordonwrath
