UPDATE: Forum set up with secure SSL
Postby plexus » 2016-Nov-Wed-02-Nov
The forum will be updated to use secure SSL and https will be enabled. The two screen shots below tell the story. I've initiated the process. please email me at admin@printrbottalk.com if you find the forum is not working as I do not monitor it every day.
thanks
Re: UPDATE: Forum set up with secure SSL
Postby Mooselake » 2016-Nov-Wed-10-Nov
Now all our posts can flit through the Internet as gibberish, and the NSA will need to read directly from the site!
Of course I'm skeptical of this encrypt everything movement...
Does this mean you're switching hosts?
Postby PxT » 2016-Nov-Wed-14-Nov
With Let's Encrypt offering free & trusted certificates there really is no reason NOT to enable HTTPS and Dreamhost makes it very easy.
HTTPS connection is working fine here but most browsers won't display the lock icon in the address bar because you're loading some insecure content. Looks like the culprit is wiki_link.png which is included on every page and is hard-coded to http. You should make sure every resource is loaded using a relative URL, or using https if you are pulling in off-site scripts (such as Google analytics, etc)
Postby plexus » 2016-Nov-Wed-14-Nov
PxT wrote:With Let's Encrypt offering free & trusted certificates there really is no reason NOT to enable HTTPS and Dreamhost makes it very easy.
Excellent. Thanks for the valuable tip! I actually know very little about HTTPS but as you say Dreamhost made it easy. I will try and remedy this http link and may as you to test it when I get it sorted out.
PxT, if I can't sort out that png http issue, does that mean the whole site is not https compliant? In other words, is all this for nought if that link isn't made secure?
@moose - I'm not switching hosts. as PxT pointed out, Dreamhost has everything I/we need to make this happen with no cost (so far). The reason for doing this is because I don't want Tapatalk to become disabled and if Apple et al are requiring secure connections there may be other implications.
Postby PxT » 2016-Nov-Wed-15-Nov
Yes and no. I mean you really want the entire site to be https capable because then users will see the padlock symbol in their browser and will know that encryption is working properly. All is then right with the world and puppies and rainbows fall from the sky, etc. As it is right now they'll either see no padlock or a broken/disconnected padlock, depending on the browser. In practical terms the only thing being sent insecurely is that single wiki image file so it's not a massive problem, but users who don't understand this stuff inside and out won't know that -- they just see that the site isn't "secure".
As far as Tapatalk is concerned, I don't think it's loading the main UI anyway so that image file is probably irrelevant. I suspect it is hitting some XML or JSON feed somewhere to get the forum data (which is very likely to be served successfully over https). The only way to know is to try it and I don't use Tapatalk so I can't really help there unfortunately.
Return to Forum talk
