Printrbot Talk Forum • View topic - Gluing Ninjaflex to Ninjaflex
Postby RetireeJay » 2016-May-Fri-09-May
Sometimes we can't print a complete object all in one go due to the limitations of 3D printing (unsupported overhangs, for example). So then we need to print sub-parts and glue them together. I'm working on a project right now using Ninjaflex (actually their "Semi-Flex"), and I needed to glue the parts together. Searching here and in Google, I didn't find any good candidates. The sources said that Ninjaflex has "low surface energy" and doesn't stick to much of anything. The only suggestion was Gorrila Glue, but I have read where it cures brittle and I needed something flexible.
So I just tried plain old 100% and it works great! It doesn't swell upon curing like Gorilla Glue, and it pretty much matches the flexibility of the Ninjaflex. It sticks more than well enough for my purposes.
  • 2
Re: Gluing Ninjaflex to Ninjaflex
Postby thawkins » 2016-May-Sat-08-May
Return to Material talk
