Huge CoreXY (400mmx400mmx200mm)
Postby orangefurball » 2016-Feb-Mon-02-Feb
Hey everyone!
So with my Thingybot Kickstarter getting funded I needed to have a printer to print large batches of parts.
I decided to go with a CoreXY design just because and I used 15mm Openbeam extrusions for the frame.
There is the printer. Still doesn't have an official name, it uses a RAMPS board with a full graphic display. It features an E3D v6 (soon to be Volcano) and a massive 400mmx400mmx200mm build volume. Obviously that is not for one large object as it would be a waste and probably destroy the printer. But for a lot of little things it works well.
Still to do - enclose it and have an exhaust port going out of the window behind the machine for ABS, and of course add heated beds. But the machine is fully functional!
If anyone wants the design files or more information let me know!
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Re: Huge CoreXY (400mmx400mmx200mm)
Postby mdfast1 » 2016-Mar-Wed-00-Mar
Very cool looking, how does it print?
UBIS 13
Printrbot LC+ - Operational
Printrbot Original- Donated
GT2 - 20 Tooth Pulleys
GT2 Belts
Brass Threaded Rods
Spur Gears from drawcut
.35mm nozzle
mdfast1
Postby ktfergus » 2016-Mar-Wed-20-Mar
Very impressive! Both the Thingybot & that 400mm beast.
I suggest "The Goliath"
ktfergus
Postby orangefurball » 2016-Mar-Thu-12-Mar
mdfast1 wrote:Very cool looking, how does it print?
I haven't done too much on it yet, but I did do a batch of 60 key chains for a local business. It was wonderful being able to just start one print and finish a job. They came out good, but it's nothing super high res. Though that's not what this design was for. The Thingybot parts that it will print don't need to be high res!
ktfergus wrote:Very impressive! Both the Thingybot & that 400mm beast.
Thank you! I love the name! I'll have to print up a nameplate and mount it on the front. I left a few extra nuts in the Openbeam for that purpose!
orangefurball
Laser scintillater
Postby mdfast1 » 2016-Mar-Sat-15-Mar
I like the Goliath as well! Congrats on the Thingybot success. Looks like a solid printer, just need to convince myself I need another bot to fiddle with. Deltas being that much more fiddly and all.
UBIS 13
GT2 Belts
Brass Threaded Rods
.35mm nozzle
mdfast1
Postby orangefurball » 2016-Mar-Mon-02-Mar
mdfast1 wrote:I like the Goliath as well! Congrats on the Thingybot success. Looks like a solid printer, just need to convince myself I need another bot to fiddle with. Deltas being that much more fiddly and all.
Thank you!
Deltas aren't as difficult as they seem, designing one is kind of difficult but using it is only a bit harder than a standard Cartesian printer!
orangefurball
Laser scintillater
Return to Showcase
