I have a PB SM with a Rev D printrboard and E3d V6 Hotend.
I am upgrading to Marlin 1.1.9 which has been an interesting experience.
Marlin 1.1.9 has software noise filter off by default which causes my Y homing to throw kill errors. I can of course switch it back on and this prevents the errors but I'd like to try the hardware fix suggested in the Marlin Docs of adding a 100nf cap to the endstop switch.
Before I dismantle everything to get at the endstops I would like to try it out to see if it solves the problem and thought of putting the caps in at the connector end as in the picture below as it's easier to get to:
(I know that is the X endstop it's just to show what I'm thinking of doing).
So a few questions:
1. Does the postion of the Cap (ie at the switch or at the connector) make a difference?
2. Can I/should I add a Cap for the Z probe?
3. If I do add a Cap for the Z probe do I need a different Cap?
4. I have a Rev F4 printrboard which I never got around to installing. Does this have any advantages in this area (ie endstop caps on the board)?
5. Any Gotchas with regard to installing a Rev F4 board other than stepper direction changes?
Thanks.
