scripts for l2 bot
Re: scripts for l2 bot
Postby Mooselake » 2019-Dec-Wed-13-Dec
Spammer, of course. The malicious link has been edited to protect the innocent, and the post will stay here a bit while we do some forensics and punish the miscreant to the best of our abilities
Postby RetireeJay » 2019-Dec-Wed-17-Dec
The original post has now been completely removed.
Return to Software usage talk
