Printrbot Talk Forum • View topic - Where can I download the official printrbot Firmware
Postby thesayianman » 2019-Apr-Wed-00-Apr
Hey Guys
Are there links to where I can download the compiled firmware that was provided by PrintrBot for the simple metal. I plan on upgrading the hotend on it to a E3D V6, but in case things go wrong I want to be able to revert back to previous hardware and firmware.
thesayianman
Re: Where can I download the official printrbot Firmware
Postby RetireeJay » 2019-Apr-Wed-08-Apr
You can find compiled versions for several variants of Printrbot at
The Wiki in this forum has that link as well as quite a bit of other information. Note that the Wiki has not been updated in a few years, so use it with caution, but much of the descriptive material in there is still relevant. Where is the Wiki you ask? Just click on the red-beige-and white "Printrbot Wiki" button next to the "Search..." text box.
Postby thesayianman » 2019-Apr-Wed-10-Apr
thesayianman
