Printrbot Talk Forum • View topic - Any soure for Printrboards?
Postby daveculp » 2019-Mar-Sun-22-Mar
II have 2 Printrbots, a Simple Metal and a Metal Plus. Due to life I havent really used them in about a year. I would like to keep these printers going for as long as possible. I know I can get printheads for them but over my time owning them I ve had a board or two go bad.
Is there a source for boards or another board that can work?
daveculp
Re: Any soure for Printrboards?
Postby RetireeJay » 2019-Mar-Mon-09-Mar
Return to Need a part
