Printrbot Talk Forum • View topic - Play Under Re? Construction
Postby novice » 2018-Aug-Wed-09-Aug
It was too hard too resist a recent Amazon Play price of $217. Also found a slightly used Matrix upgrade on the web and here is where it's all at as of yesterday. Kinda suspected there may be issue with the Matrix for someone to be selling it so soon (little sign of use) and maybe am reading too much into this, but the set of Z axis bearings on the left side do not align as well as one would think they should. Will probably end up filing the carriage pockets for them in attempt to fine tune that. First I'll run it as is... before doing any damage with tool. Cause Damage is my middle name.
Anyways thought I'd throw this out there as a teaser of my upcoming winter project and figure it'll give me a better understanding of where and which side the parts should go on that similar Play v2 kit setting in a box somewhere around here.
I've read as much as I can find, but still unsure if my chineeze 100k ntc 3950 thermistor that came with the heatplate will deliver accurate reading thru the F6 board?
Re: Play Under Re? Construction
Postby ktfergus » 2018-Aug-Wed-10-Aug
Best of luck. Mach-chris used to post regularly when I first got here. Here's a thread about the upgrade: viewtopic.php?t=11284
Might not hurt to shoot him a PM or email with any questions, he might even have spare parts lying around.
-Kelly
PrintrBot Model: 1403 (Simple Metal Assembled) ::
ktfergus
Postby novice » 2018-Aug-Wed-12-Aug
Thank you Kelly, just did that.
With regard to my imported bed thermistor 100k ntc 3950 ?, I swear the more I read here on that the more confused I become. Is this the one I need or likely that I'll have issue with that choice?
Postby Mooselake » 2018-Aug-Fri-14-Aug
From ubishotends.com "The standard temperature sensor that shipped with Printrbots was a EPCOS NTC thermistor G560 / 100K / 1%."
The easy way would be to purchase one of the "official" thermistors from a reliable source. Otherwise try comparing the specs on what you got compared to what you need, then factor in a chance of counterfeits or cheap outtakes. If it were me I'd try the one you received and see what happens, then replace if necessary.
Maybe RJ has a comment. He's a real EE, I just stayed at a Holiday Express^^^^^^^^^^^^^^^EE school until they gave me a piece of paper.
Postby novice » 2018-Aug-Fri-15-Aug
Postby RetireeJay » 2018-Aug-Fri-22-Aug
I'm pretty sure the bed thermistor was the EPCOS 100K. Different thermistors do indeed have different characteristics. If you are up to compiling your own firmware, several different thermistor tables are built into Marlin; you just select the appropriate one in Configuration.h. If you don't want to compile your own firmware, then another choice you have is to make up your own little table of temperature settings versus actual temperatures. In other words, maybe you set a bed temperature of 70C and it actually goes to 65C. Then anytime you want 65C you just tell it 70C. (One of my early on-the-job computer programmer mentors taught me early on that you can lie to software without a guilty conscience.) OR... you just look around for the actual correct thermistor.
Postby novice » 2018-Sep-Tue-10-Sep
Ended up borrowing the correct bed thermistor from one of the other printrbots around here. When I identify an outside source for another one, will remedy that. Suspect compiling firmware is a couple if not more pay grades above me.
Tried to contact Chris @ Matrix.Precision with the email address posted in the link Kelly provided above; no response. Assembled it as is with the tight Z bearing alignment, thus far on two prints no Z issue seen. Have xtra bearings and Z rods, if it becomes an issue will tear it down and reluctantly file away at the alum carriage slots.
This was a NIB Play and when I started the upper fan did not function, ultimately found an open connection (broken wire) to the fan. Found this instructable on flashing to follow which provided a valid link to a recent/current Play F6 hexidecimal file and while that was not my fan issue, it was still a productive learning experience on a Holiday that was far too hot and muggy around here to be outside.
Return to Showcase
