by RetireeJay » 2018-Mar-Wed-15-Mar
Do you have a caliper? You could print just the first layer of a print, then kill the print, remove it, and measure the thickness of the layer. If you're using a 0.4mm nozzle, then the thickness should be significantly less, like 0.25 or less. The thinner the layer, the more force you've exerted to squish it onto the bed. Adjust your first-layer Z offset appropriately.
How thin can you go? You've gone too far if:
(a) There's no layer there at all, and your extruder clicks. In other words, zero clearance and the nozzle is blocked; nothing is coming out.
(b) You have a first layer, but every time the printhead lays down a new trace beside an existing trace, it plows up some of the existing trace so after the first layer is done it looks like a freshly-plowed field with little ridges for every pass of the printhead. If your Z correction is not right, you might see this plowed-up effect towards one side or one corner of the print.
I generally specify my first layer as double-width and a bit thicker than the other layers in the slicer in order to get more "squish".
Of course, all the potions and enhancers you add won't do any good if the surface is not clean to start with. Isopropyl alcohol is good for most cleaning purposes.
And, in the end, there can be bad batches of filament that just don't behave right. Try a different spool, one that you know worked before if possible.
