My simple metal died in the middle of a print the other day.
I came in to find it stopped in the middle of the print
I thought - well, maybe I had a short power failure?
so, I scraped off the half print and tried to start the job anew.
I use an LCD panel to print from SD Cards
when I tried to restart my print job the LCD screen flickered and reset to the Info Screen
I did this several times, resetting the power each time and got the same results
Then I tried to just heat the extruder so that I could remove the filament.
I got the same flicker and reset to the Info Screen when I depressed the knob to select the temp.
I am also seeing this behavior when I attempt to heat the bed via the LCD
If I attempt to move any of the axis, or perform an auto home, the bot starts to move sluggishly then stops after a cm or two and the motor makes somewhat of a grinding noise (stalling?)
I checked all of the connections under the bot and everything appears to be in place.
I am not sure how to troubleshoot this from this point
I am looking for any suggestions on my next step for troubleshooting this issue
