Printrbot Talk Forum • View topic - Replacing the sensor with a BLTouch
Postby AgentTDM » 2017-Oct-Thu-23-Oct
Is there any way possible to modify the firmware of a Printrbot Simple Metal to where its board (Mine is a Rev F4) can use a BLTouch? If it's just a case of the board not being able to supply enough power, I can always power the sensor using one of the 5v wires on my ATX supply. I added a BLTouch to one of my other printers a while back and it has done very well.
AgentTDM
Re: Replacing the sensor with a BLTouch
Postby cbxbiker61 » 2017-Oct-Fri-01-Oct
For the most part there really isn't a good reason to go from the inductive sensor to the BLTouch. If your inductive isn't working properly, fix it. The BLTouch isn't without it's own set of problems.
Postby AgentTDM » 2017-Oct-Fri-02-Oct
AgentTDM
Postby cbxbiker61 » 2017-Oct-Fri-03-Oct
Anything is possible with the board...it does have an expansion bus. Best of luck hacking the firmware.
Postby AgentTDM » 2017-Oct-Fri-07-Oct
AgentTDM
Postby TutherJay » 2018-Feb-Wed-19-Feb
Well, I see this is growing stale, but I _WAS_ rather hoping to find more activity on this, as I just got one for my old Plus (which didn't come with a sensor in the first place, as yours did). So in my case I also have a plenty good reason, I believe, to wax brave and hopeful.
Apparently nobody else has anything to offer, but I am curious if you've found a way to insert tab B into slot A, as they say??? Or are you still interested, or did you move in another direction??
Tweaking Marlin shouldn't be that tough, I wouldn't think, but perhaps that's optomistic. It's certainly not an unexplored, undocumented, stab in the dark as some seem to believe! At least it's not obfuscated by a serious language barrier, as with the BLTouch documentation, eh?
Hope you've mastered it - whether or not it helps me.
TutherJay
PrintRbot+ v2 built from kit, hatched Sept 9, 2013
PowerTower & RPi/OctoPrint kits added
Repetier/Slic3r mostly; sometimes RPi:OctoPrint
1.75mm via direct drive gear head extruder
(temporarily abandoning Bowden mod - Bridge wouldn't fit thru)
E3D v5 hotend w/ Volcano Eruption upgrade
Stock LC ply bed now adjusted by 3 points, not 4
6mm heated glass (non-borosilicate) (now missing divot from BluPrint adhering TOO well)
<sigh>
TutherJay
