Seeking working firmware source for Simple Metal (rev F6)
Postby automatonmaker » 2017-Apr-Wed-10-Apr
I've upgraded my Simple Metal (rev F6 Printrboard) to an E3D v6 hot end and Titan extruder (I'm happy to share how I mounted the Titan using a custom-designed, printed mount), and now need to edit the thermistor type and max temp values. The versions of firmware I've found so far on Github don't compile without errors using the latest Arduino IDE with Teensyduino added in, and selecting the Teensy board. So far Printrbot has not been very helpful. Does anyone have a link to the right source code that I can compile and then flash?
automatonmaker
Re: Seeking working firmware source for Simple Metal (rev F6
Postby cbxbiker61 » 2017-Jun-Wed-16-Jun
I could get you a copy of my Marlin 1.1.3 code once I have embedded link permission. See my new post about Marlin 1.1.3 Simple code.
Postby RetireeJay » 2017-Jun-Wed-16-Jun
I find that the combination of editing with Notepad++ and compiling with PlatformIO is far, far superior to trying to use the Arduino IDE. It may take a little bit of tweaking, but I've been able to get even the latest version of Marlin to compile under this system. It's important to correctly define the motherboard both in the Marlin code and in the PlatformIO folder that you add to the Marlin folder; if they both say the same thing, then you should be able to compile.
See viewtopic.php?f=22&t=10160
