Z axis motor "Y" cable splitter
Postby Bellus » 2015-Feb-Tue-17-Feb
Does anyone know where I can purchase a splitter cable for hooking up two Z cables to one spot. Similar to one that comes with the Plus. I have searched a bit, but I think I am missing the magic words.
Bellus
Re: Z axis motor
Postby Mooselake » 2015-Feb-Wed-16-Feb
I tried googling variations on "printrboard motor splitter" and didn't come up with anything useful. Printrbot originally sold the motors already joined together with one connector, like in my Kickstarter Klassic Plus. If that's what you want they may still be doing the same thing with the current dual Z motor models and could sell you a dual motor package. I didn't search any of the printrboard clone sellers, but they might have something too.
Printrbot sells motor extension cables, so you could do a little cutting, stripping, and soldering and make your own, or you could get a pair of motors with the connectors installed and do the same thing. It depends on what your goals are.
You can search the forum to find the part numbers for the connectors used and make your own from scratch, too.
Re: Z axis motor "Y" cable splitter
Postby orangefurball » 2015-Feb-Thu-15-Feb
Here you go,
http://makemendel.com/mechanical-parts/ ... -for-prusa
That has worked for me in the past!
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Re: Z axis motor
Postby midnkight » 2015-Feb-Fri-01-Feb
I used computer extension cable and y cable. the connect had to be modified a little, but your local computer parts store my have the items. Amazon has quiet a few 2 pin, 3 pin, and 4 pin cables.
midnkight
Re: Z axis motor
Postby liamhenry21 » 2017-May-Thu-01-May
This tutorial is intended for rack holders and other 3D printers that use 2 stepper motors for the Z axis, as usually seen in the patterns of Brosa or Mendel of printers, and many more.
The default configuration for most electronics controllers such as Rams is that the motors are connected in parallel. But as I will try to explain, it could be more useful to connect the motors in a series instead.
liamhenry21
Re: Z axis motor
Postby Mooselake » 2017-May-Thu-13-May
Another of our necroposting Pakistani friends. Since none of them have ever responded to polite requests for info about their 3D printers this one has joined the others in the forum banlist. Have to say I'm disappointed, would like somebody from that part of the world to actually have a 3D printer. For a change I gave him/her negative feedback and asked if they'd prove me wrong.
Since they're not banned it's not really an excuse to pull out the machine guns, but while I'm not a fan of music videos I like the song. Guess I'm showing my moosely maturity
Return to Need a part
