Taulman Spool Webbing
Postby ktfergus » 2017-May-Mon-14-May
Last week, I was noodling around on the Taulman website when I came across this page. I've been printing with various Taulman products for nearly two years & never realized you weren't supposed to remove the mesh/webbing on their small spools.
I just wanted to post this so no one makes the same silly mistake...
-Kelly
ktfergus
Re: Taulman Spool Webbing
Postby RetireeJay » 2017-May-Mon-14-May
I've been taking it off too!
Postby Mooselake » 2017-May-Mon-14-May
I think PxT told me to keep it on, although it might have been Dr. Google
Postby PxT » 2017-May-Tue-10-May
Haha, oops. Don't think it was me because I've been taking it off. This has got to be a pretty common "mistake". I mean it's not even really a mistake because obviously people have been able to print just fine without the webbing.
Return to Material talk
