Bye bye ABS
Bye bye ABS
Postby usagi » 2016-Mar-Sun-02-Mar
PETG is everything you wished ABS to be.
  • no warping
  • no smell
  • non brittle
  • extreme strength
  • fantastic layer adhesion
  • non hygroscopic
bye bye ABS. was nice knowing you.
very happy with this stuff!
http://www.amazon.com/filament-1-75mm-M ... B00ZAUQZTA
usagi
Bye bye ABS
Re: Bye bye ABS
Postby cacb » 2016-Mar-Sun-03-Mar
usagi wrote:PETG is everything you wished ABS to be.
  • no warping
  • no smell
  • non brittle
  • extreme strength
  • non hygroscopic
Very interesting, I have a roll of ABS, but cannot stand the smell. What is the typical hotend and bed temperatures for printing with PETG?
cacb
Re: Bye bye ABS
Postby usagi » 2016-Mar-Sun-03-Mar
I print PETG with 65C bed and 230C extruder.
the strength of PETG printed parts really is unbelievable. when a part does break, it rips diagonally, giving a jagged edge across many layers. where PLA or ABS would separate cleanly along one or two layers, like cleaving mica sheets.
the only downside is that PETG adhesion is so great, it takes a bit of extra work to clean off support material. small price to pay.
usagi
Re: Bye bye ABS
Postby RetireeJay » 2016-Mar-Sun-06-Mar
Hey, I fully agree with the problems with ABS. I never used more than a few feet of it before giving up due to the smell. Although different people's noses respond differently; Plexus doesn't mind the smell.
Anyway, just for completion, I want to point out that Taulman3D's "T-Glase" is PET-T, a close cousin of PETG. I've been using T-Glase for years now and am very satisfied with it. I'm running just about identical temperatures as mentioned above.
Re: Bye bye ABS
Postby cacb » 2016-Mar-Sun-10-Mar
usagi wrote:I print PETG with 65C bed and 230C extruder.
Thanks! That makes it easy. I will probably order some PETG next time around then.
cacb
Re: Bye bye ABS
Postby ktfergus » 2016-Mar-Sun-12-Mar
I agree 100%; I switched to PETG several months ago after ABS kept warping on large prints, even with a bed temp of 110C.
I've been happy with eSun's black PETG & just started using Taulman's Tech-G with good results. I still get occasional curling but nothing like ABS.
ktfergus
Re: Bye bye ABS
Postby usagi » 2016-Mar-Sun-15-Mar
oh yeah, I print on PEI. PETG adhesion is excellent.
usagi
Re: Bye bye ABS
Postby MileHigh3DII » 2016-Apr-Thu-23-Apr
What kind of layer height and speeds are you running? I've played a bit with Tglase, but thru a 0.4 I found it to be stringy and had to be printed at a slow speed. I have an old PB+ that I set up with a 0.8 nozzle for vase type stuff at 0.8 layers- and that is pretty interesting, but not really applicable to parts with details.
What am I missing?
MileHigh3DII
Re: Bye bye ABS
Postby RetireeJay » 2016-Apr-Fri-05-Apr
I generally print at 0.25 or 0.2mm layer height. With my E3Dv5, I had to increase the printing temperature to 250C from the 230 that I was using with the Ubis. My print speed is 50mm/sec. With these settings, I get consistent extrusion volume and good layer-to-layer adhesion.
Re: Bye bye ABS
Postby Chyn » 2016-Jul-Fri-01-Jul
How about costs? Is it cheaper than ABS or at least the same?
Chyn
Re: Bye bye ABS
Postby teicher » 2016-Jul-Sat-20-Jul
Can you print PETG without a heated bed?
teicher
Re: Bye bye ABS
Postby thawkins » 2016-Jul-Sun-03-Jul
RetireeJay wrote:Hey, I fully agree with the problems with ABS. I never used more than a few feet of it before giving up due to the smell. Although different people's noses respond differently; Plexus doesn't mind the smell.
I have never noticed any smell with ABS and I never had any significant issues with warping.
I like PETG, but nothing is perfect, it has a lower temperature tolerance than ABS and is more viscous and sticky thus prone to stringing, prints can come out looking like hairy fur balls.
Re: Bye bye ABS
Postby alex2017 » 2017-Mar-Fri-03-Mar
alex2017
Re: Bye bye ABS
Postby RetireeJay » 2017-Mar-Fri-06-Mar
See the second post in this thread. ;)
Re: Bye bye ABS
Postby MileHigh3DII » 2017-May-Tue-04-May
The ABS never bothered me, but I'm a chemist that has worked around solvents and resins, so that maybe why I don't find it as offensive. Interesting spread on sensativities.
I will sing the praises of the PETG though. I have a spool of ColorFabb nGen silver filament that I'm in love with for now. It has excercized by bed/warping demons I had with ABS. I could manage them- but I was totally going Kluge by taping down the brim corners with scotch tape- I even tacked down a corner of a build that was lifting. Not fun with a heated bed and moving extruder gantry.
That Amphora has great adhesion to BuildTak with some glue on it. Might not even need the glue. Had to heat a printed part to 40C on the bed to get the part knife under a corner to get it off. Nice smoothness. Good flow.
I've used TGlase, but that wasn't pigmented and I didn't get nice looking parts out of a 2. layer .4 nozzle print- though my 0.8 printer loves it.
I'd be really interested in getting in some Amphora pellets in to play with in my Filastruder.
MileHigh3DII
Return to Material talk
