Printrbot Talk Forum • View topic - Printrbot V2 - start guide
Postby guilhermemauro » 2016-Feb-Thu-07-Feb
Hello guys, I win a Printrbot V2 and I'm confused about how I can start with printer (Power On, Calibrate and print). Somebody can help me with a link or file guide?
guilhermemauro
Re: Printrbot V2 - start guide
Postby RetireeJay » 2016-Feb-Thu-10-Feb
You could start with Printrbot's own documentation here:
And then there are thousands of posts in this forum to address almost any conceivable question.
Postby Mooselake » 2016-Feb-Thu-11-Feb
Hi, guilhermemauro! Was the Printrbot guide any help? Did you get your printer going?
I see you're using a VPN out of Brazil. While there's a number of legitimate reasons to do this, the one you've picked has been blacklisted by a number of anti-hacker and anti-spam organizations. It might be good for you to consider another network provider. Can you tell us where you're really located? Are you Guilherme Mauro, the cyclist?
Postby guilhermemauro » 2016-Feb-Thu-16-Feb
guilhermemauro
Return to My first blob
