Heated Bed is not heating
Postby venkei » 2015-Dec-Mon-06-Dec
Hello All,
Some one please help me regarding heated bed.
Installed new heated bed with thermostor to my printrbot metal plus, but unfortunately heated bed not working. I gave temperature settings in simplify3d as
Primary Extruder: T0: 215
Heated Bed: T1: 70
When i give print, it will not start printing. Unfortunately extruder temperature coming down and heated bed temperature shows 0
venkei
Re: Heated Bed is not heating
Postby RetireeJay » 2015-Dec-Mon-07-Dec
If the heated bed temperature shows zero, then you don't have a good connection to the thermistor; it's an open circuit. And as a matter of safety, the firmware won't allow you to heat the bed unless you have at least a reasonable reading from the thermistor. (Same goes for the extruder). Zero degrees indicates an open circuit; temperature over 300C indicates a short circuit, and either condition prevents operation.
Postby chengal » 2015-Dec-Mon-08-Dec
Thanks a lot Jay,
Iam checking thermistor connections, but i want to know the value of resistor for thermistor.
chengal
Postby RetireeJay » 2015-Dec-Mon-09-Dec
At room temperature, it's somewhere close to 100K ohms.
Postby Mooselake » 2015-Dec-Mon-13-Dec
Hi, Venkei/Chengal! Welcome to the forum!
It looks like you're posting from Kuwait, and you may be our first member from there. Are you having problems that made you need to create two different accounts from the same IP address?
Postby chengal » 2015-Dec-Tue-06-Dec
Mr.Jay,
I used 100K ohms thermistor, but still it is not heating. Is there any issue with settings? If yes please let me know the settings as iam using simplify3d.
chengal
Postby RetireeJay » 2015-Dec-Tue-07-Dec
I don't have Simplify3D, so I'm not sure of the settings. But let's verify something.
You should have some kind of a User Interface or Status screen that shows you the state of your printer: where it is in X, Y, Z, and what the temperatures are for both the heated bed and the extruder. When no heat has been turned on, both the heated bed and the extruder should read about room temperature, that is in the range of 20C to 30C. Ideally, they would be identical, and accurate, but in reality the circuit is optimized for accuracy at higher temperatures so there is some uncertainty at room temp. However, zero C would mean you have a bad connection somewhere. Make sure you have the bed's thermistor plugged in to the correct header on the board.
Postby venkei » 2015-Dec-Wed-02-Dec
Thank-you Jay,
I want to know one thing, the heated bed will not work without thermistor?.
Iam attaching the photos of my heated bed connections.
1. Heated bed wires red and black given to green terminal.
2. Thermistor wires plugged to white terminal in the bottom.
3. ATX power supply wires given to top right side terminal.
venkei
Postby RetireeJay » 2015-Dec-Wed-08-Dec
venkei wrote:I want to know one thing, the heated bed will not work without thermistor?.
Correct - the heated bed will not work in a Printrbot system without a thermistor connected.
But what is that device in your picture? It doesn't look like any thermistor I ever saw. It might be a thermistor, but normally the thermistors shipped by Printrbot are little glass or ceramic beads, not metal cylinders. And thermistors don't have a "polarity" (an orientation for + and - ) as your device appears to have. What you have looks more like either a fuse or maybe a thermal switch, which would turn on and off when the temperature crosses a certain threshold - probably marked on the device. If it's a thermal switch then it's totally incompatible with the control circuit on the Printrboard. (There would be a way to use the bed with this switch, but as far as the Printrboard is concerned, you would have to operate as if the bed was not heated. You would have no software control or readout of bed temperature.)
I'm guessing that you did not buy this heated bed from Printrbot. Would you mind telling us where you did get it? Maybe with enough information, we can track down the specifications for that strange device.
1. Yes, this is the right connector for the heated bed heater. In this case, polarity does not matter (red and black are interchangeable).
2. Yes, you have circled the correct connector for the thermistor, labeled "T-BED." Again, polarity does not matter (white and black are interchangeable).
3. Correct
Postby venkei » 2015-Dec-Thu-05-Dec
Thanks a lot Mr. Jay for your valuable suggestions.
I got heated bed from printrbot, but i did not get any thermistor from them. So i bought it from local market. Any how i ordered 100k thermistor from Amazon.
venkei
Postby RetireeJay » 2015-Dec-Thu-07-Dec
venkei wrote:Any how i ordered 100k thermistor from Amazon.
Not all 100k thermistors are alike. Different models have different curves. But don't worry; even if your thermistor doesn't match the curve built into the firmware, you can still use it. The thing is you may have to experiment to find out what setpoint temperature gives you the results you want. If you post the specific model number of the thermistor you bought, I may be able to help you answer the question.
Postby venkei » 2015-Dec-Sun-03-Dec
Mr.Jay,
Thanks a lot for your support. I got the thermistor and now my heated bed working perfectly.
venkei
Return to My first blob
