First test not bad... but X and Y way off
Postby russellriker » 2015-Aug-Wed-13-Aug
So got my new Printrbot Metal Simple last night, and was really happy with my first few prints. Yeah there might have been a couple stops and restarts.
But the thing that was causing me the most problems was the all the prints where starting off in the back right corner of a bed? Which I totally didn't get, because the test print that the folks at Printrbot did and was smack dab in the middle of the bed when I un-boxed it? so i started playing around with the M212 code and moving my x and y closer to the center and saving them to the config with M500. but if Printrbot had printed in the center of the bed, why would I have to set x and y again? Or is some setting I missed in CURA?
If anyone else has seen this, would love to find out more from you.
Thanks
Russ
russellriker
Re: First test not bad... but X and Y way off
Postby cacb » 2015-Aug-Wed-14-Aug
First off make sure the model is in the center in Cura and that your Cura settings are for Printrbot Metal Simple and not some other printer. If the above is ok, you should be almost in the middle, except for the ~25mm offset in X direction that is default in the printer (but I think possibly incorrect).
cacb
Postby bbrown64 » 2015-Aug-Wed-14-Aug
There are settings in Cura that define the print area. Once the 150x150x150 settings are set then the print should start in the center of the bed.
Bill Brown
Tulsa, OK
bbrown64
Postby cacb » 2015-Aug-Wed-15-Aug
bbrown64 wrote:There are settings in Cura that define the print area. Once the 150x150x150 settings are set then the print should start in the center of the bed.
Well it isn't exactly in the center. At least not last time I used Cura (15.02.1). Same thing when using OctoPrint. It is off in X by the same amount the Z probe is offset from the hotend.
cacb
Postby RetireeJay » 2015-Aug-Wed-17-Aug
Try adding G28 X0 after the G29 leveling command, to re-zero the X axis.
It seems like this is a bug in the auto-leveling firmware.
Return to My first blob
