I need a small part printed with a Simple Metal
Postby RCBrust » 2015-Jun-Fri-06-Jun
Hello,
I am contemplating purchasing a Printrbot Simple Metal to print some small enclosures for an electronic device. The parts are only about 1.5" x 1" by 1/4" high so I'm concerned about how they'll look and dimensional accuracy. Before I invest in the printer, I was wondering if anyone with a Simple Metal would be willing to print one for me so I can see how they'd turn out. I'm more than happy to pay for your time, materials and postage. I'm in PA.
Thanks,
Randy
RCBrust
Re: I need a small part printed with a Simple Metal
Postby lairdb » 2015-Jun-Fri-10-Jun
RCBrust wrote:Hello,
Thanks,
Randy
From my vast experience of a couple of months: Dimensional accuracy for an enclosure is likely to be satisfactory; appearance will depend a lot on your standards and whether you want to do any postprocessing. Both will depend somewhat on whether the model is structured with deposition printing in mind. Post your models so folks can see what you want to produce.
Simple Metal Kit, heated bed
Mods: blower fan with self-remixed blower duct
Usually PLA on kapton with AquaNet.
Usually Cura.
lairdb
Postby RCBrust » 2015-Jun-Fri-11-Jun
Let me get the model finished up and I'll post the SLT, probably this weekend. Here's a pic of what I'm looking to do:
It's pretty simple, just a shell with a window in the base.
Thanks,
Randy
RCBrust
Postby lairdb » 2015-Jun-Fri-12-Jun
Usually Cura.
lairdb
Postby RCBrust » 2015-Jun-Fri-12-Jun
Noted, will change to chamfers, thanks.
Randy
RCBrust
Or fillet the chamfer, if you like keeping some of the curve.
Usually Cura.
lairdb
Postby RetireeJay » 2015-Jun-Fri-14-Jun
That is a great reference! I just read the whole thing, and the explanations are wonderful.
Postby lairdb » 2015-Jun-Fri-14-Jun
Usually Cura.
lairdb
Postby RCBrust » 2015-Jun-Sat-06-Jun
I've attached an STL file. If anyone with a Simple Metal or similar would be willing to print it, I'd really appreciate it. Shouldn't take much filament! :P
Thanks,
Randy
RCBrust
Postby JonS » 2015-Jun-Sat-09-Jun
If no one on this forum is willing to help you, you could get it printed by someone near you with a Simple Metal via 3dhubs.com.
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Postby RCBrust » 2015-Jun-Sat-11-Jun
That's a good tip, thanks.
Randy
RCBrust
Postby RetireeJay » 2015-Jun-Sat-11-Jun
I'd suggest you look on the Showcase part of the forum to see what printed products look like Also look at the thread "Printing Small." No one is ever going to mistake printed parts for injection-molded parts, but nevertheless they can be quite attractive. If you have a heated bed and print with ABS, you can do vapor smoothing and get some very nice-looking parts.
There are a variety of settings, particularly layer height, that affect print aesthetics. These same settings are available on all models of Printrbot. For the most part, aside from sheer size, the different models of Printrbot can all produce essentially the same quality prints. Some of them can run faster; the Simple will be the slowest of the family for a given quality.
It sounds like you're planning to make several of these objects, perhaps for sale as part of a larger assembly or project? If you are really interested in quantity production, then a larger model Printrbot can print more of them in a single run, tiling them on the bed.
If these parts will be joined with other things in an assembly, do you have expectations or requirements for mechanical strength? Tolerance for fit with other objects? Temperature tolerance? (PLA can't take the heat of the interior of a car in the summertime). Safety concerns? Food-grade materials? Requirements for color, opacity, surface sheen, etc?
If dimensional tolerance is your biggest concern, then the answer to your question is that you can fine-tune your settings (and model, if necessary) to get pretty tight tolerance, but don't expect repeatability to be better than one or two tenths of a millimeter from hobbyist machines.
I say all this because if your purchase decision depends on having a truly representative sample from someone on this forum, then you've got to be very thorough in how you specify what you need. A thousand of us could print your file, and there's be a thousand tiny, tiny (or big) differences between all of them.
RCBrust wrote:That's a good tip, thanks.
Randy
And there are services like Shapeways which can print your part with pretty close dimensional tolerances and reasonable prices - but it won't be using the FDM process like Printrbots.
Postby lairdb » 2015-Jun-Sat-15-Jun
RCBrust wrote:I've attached an STL file. If anyone with a Simple Metal or similar would be willing to print it, I'd really appreciate it. Shouldn't take much filament! :P
It certainly won't take much filament if it's only 1.24mm wide, but I don't think that's what you intended. What units did you dimension in, and what's the intended size?
Also (though I know nothing of your application and could be talking through my hat), consider drafting the inside, or the top half of the inside. It's not an injection molded part, so it doesn't need it for mold release, but it might need it for ease of assembly. Could also draft the opening for the same reason.
How does it attach to... whatever it's attaching to? Do you need posts or screw bosses?
Usually Cura.
lairdb
RetireeJay wrote:And there are services like Shapeways which can print your part with pretty close dimensional tolerances and reasonable prices - but it won't be using the FDM process like Printrbots.
That has quickly become my process for work stuff: print, test, adjust, print on the Simple Metal, then once we're all satisfied, send to Shapeways for "production".
Usually Cura.
lairdb
Postby RCBrust » 2015-Jun-Sat-16-Jun
The units are inches, so it's 1.24"x0.91". I have ordered a slightly different version from Shapeways to see how they look but if I can get it good enough with a PSM, the per piece cost will be a lot less.
Thanks,
Randy
RCBrust
Postby Mach-Chris » 2015-Jun-Sat-17-Jun
it was a lot smaller than I though it would be haha,
Not perfect, but could be improved a little with some tweaking. As RJ stated, this is really just one representation of how it could look coming off a simple. There are lots of settings that could be tweaked, layer heights could be changed, nozzle sizes even if you wanted. Comes down to what you want to use them for, and how esthetically pleasing you want them to be.
~17 minutes 100% infill. PLA .100 layer height.
There is a small gap between the inner and outer walls, simplify3d didn't seem to want to fill it, it's likely too small an area (Could probably fix this by increasing the number of perimeters).
Visit Matrix Online!
Follow us on Twitter! @MatrixPrecision
Mach-Chris
Postby lairdb » 2015-Jun-Sat-19-Jun
First: Everything RJ said, in spades. You know that old joke about the control panel for men vs. women?
That's the difference between sending it to Shapeways and printing it on Printrbot (or any other FFD printer, AFAIK.)
I didn't get the hollow wall; I sliced in Cura at 0.10 layer, 0.8 shell, 0.6 bottom:
If I were to knock off that little flake on the near corner, it would be pretty good.
Usually Cura.
lairdb
Since it sounds like the OP is thinking about short run production:
At 0.10 layer height, it took about 25 minutes with the settings I had. Cura says it can fit 20 of them on the print bed at a time, and about 10 hours to print all 20, consuming 27 grams of plastic (about $0.67 worth.) The electricity probably cost more than the PLA.
Usually Cura.
lairdb
Postby Mach-Chris » 2015-Jun-Sat-19-Jun
Printed another one after tweaking a few things :)
Simplify 3d likes to autocalibrate the extrusion width to .48 unless you tell it otherwise, so I did, and the hollow walls went away.
18minutes, same settings as previous. Nice job lairdb!
Mach-Chris
Mach-Chris wrote:Printed another one after tweaking a few things :)
Good infill on the walls -- what do you think is going on with the edges?
Usually Cura.
lairdb
Postby Mach-Chris » 2015-Jun-Sat-20-Jun
Part of it was my Z calibration. I haven't been using the simple as much lately and its due for a once over, I use my Plus more frequently.I believe part of the issue is this roll of filament i'm trying to burn through with random prints. It has been giving me headaches since day one. Needless to say, I haven't gotten another roll from these guys since.
Mach-Chris
Postby RCBrust » 2015-Jun-Sat-20-Jun
Wow guys, pretty nice! If either of you are willing to send me one, PM me and I'd be happy to PayPal you to cover it.
Thanks,
Randy
RCBrust
Postby lairdb » 2015-Jun-Sun-13-Jun
I've got him covered -- making a few at different layer heights, etc.
Usually Cura.
lairdb
Return to Need a part
