Hoping to trade for some pieces [SOLVED]
Postby Desdemona1 » 2015-Mar-Thu-19-Mar
So is anyone in the upstate NY area or willing to ship items???
I am looking to have a few pieces printed out in abs as they will be for the hot end and motor. PM me for the specifics as I don't need all the pieces mentioned below.
TRI ROD MOD(No XL) thing:575393
X expanded(double precision) thing:383713
300mm Y(double precision) thing:372467
Albany, NY
I think I'd like to do something nice for somebody. I think it's good if you smile at someone, and they smile in return. Voluntary love encourages people to create a sense of friendliness.
Desdemona1
Re: In need of Jon's Expanded X axis and tri rod mod
Postby mechanizedmedic » 2015-Mar-Thu-21-Mar
If you don't get any hits here you can always find/pay someone on 3dhubs.com to print for you. Many of the operators on there have reasonable prices, especially if you need something printed in a pinch.
blog.mechanizedmedic.org
mechanizedmedic
Postby Desdemona1 » 2015-Mar-Thu-21-Mar
Thank you very much, i'll check it out now.
Edit: I can barely afford to print a third of my mod pieces lol. Oh well.
Desdemona1
Re: Hoping to trade for some pieces
Postby Desdemona1 » 2015-Apr-Mon-21-Apr
Thanks to captainserial I am no longer in need of any parts.
I'm not sure how to remove my original post?? Mod?
Desdemona1
Re: Hoping to trade for some pieces [SOLVED]
Postby RetireeJay » 2015-Apr-Tue-09-Apr
I edited the subject line of the OP to say [SOLVED] - which you could also do on any of your own posts.
-RJ
Postby Desdemona1 » 2015-Apr-Tue-21-Apr
I will remember that, thank you RJ.
Desdemona1
Return to Need a part
