Printrbot Talk Forum • View topic - Do I need a special account to make a Wiki page?
Postby orangefurball » 2015-Jan-Wed-05-Jan
Hello!
In my other thread discussing my printer design, Thawkins suggested I make a Wiki page when I post the design to keep all of info (BOM, parts, instructions, firmware, etc.) in one place.
Only thing is I don't know if I need a special account, and if its even possible I get one.
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Re: Do I need a special account to make a Wiki page?
Postby RetireeJay » 2015-Jan-Wed-09-Jan
Yes, authorship on the Wiki is restricted, to prevent spam. But you can get authorized easily; just send a PM to Plexus.
Postby orangefurball » 2015-Jan-Wed-16-Jan
Thanks! I PMed Plexus.
orangefurball
Laser scintillater
Postby thawkins » 2015-Jan-Thu-05-Jan
Postby orangefurball » 2015-Jan-Thu-18-Jan
orangefurball
Laser scintillater
Postby RetireeJay » 2015-Jan-Thu-18-Jan
I'll warn you right now... if you haven't done Wiki articles before, the syntax is not at all like making postings here on the forum. I guess it's a relative of (or subset of?) HTML. So a lot of things will be non-intuitive, like formatting with indentation, italics or bold text, headers versus body text, links, etc. etc.
Postby orangefurball » 2015-Jan-Thu-19-Jan
orangefurball
Laser scintillater
Return to Forum talk
