Printrbot Talk Forum • View topic - clicing on link in email
Postby pomonabill221 » 2013-Aug-Sun-14-Aug
This has NOTHING to do with our printers, but when I receive an email from the board that a response was posted in a thread that I am watching (like this);
viewforum.php?f=85
when I click on the link, it takes me to the;
Board index ‹ General ‹ Welcome, introductions and stories
and not the particular thread.
Is this correct? I thought the link should take me to the thread directly.
I am on other boards and it does work this way, but not here.
Also, EVERY thread that I view, the second "post" is always an ad that is blank... is this the way the board works?
hhmmmm....
Bill
PBplus V2 kit.
* NOW with AUTOLEVEL!!!!
pomonabill221
Re: clicing on link in email
Postby allanonmage » 2013-Dec-Thu-12-Dec
I agree that this is a problem. So much so that I went back in time and created this thread:
viewtopic.php?f=7&t=2870
No, I dind't go back in time, I'm just joking. But I see this phenomenon has not been addressed/fixed yet, so I'm here to bump it up the totem pole of priority.
Started with a Printrbot LC Kit; now it's a monster as big as a mid size fridge!
Single ATX Power supply, 650 watts, relay controlled heat bed
extra Z height (3+ ft) via longer rods, but I don't use it. Yet. To reduce wobble, I'm using thing:46082 under the Printrbot.
Dual heated beds, 1 currently working; space for a 3rd
Purple gluestick on glass seems to be sticky enough to get adhesion
FB album with pics: https://www.facebook.com/media/set/?set ... ec287e8726
This was supposed to be a tool, not a series of projects... grrrrr......
allanonmage
Layer 100 of 1234
allanonmage
Layer 100 of 1234
Postby kuntalghosh » 2014-Apr-Thu-11-Apr
I don't face any problem even.
kuntalghosh
Return to Forum talk
