Printrbot Thing ALERT! New Thing Found!
Talk about things - things to make, things you made
Postby Michael@Oz » 2012-May-Tue-00-May
:idea: we need a thread where people can post when they see a new Printrbot related Thing in Thingiverse. So here goes, for your making pleasure...
Subscribe (at bottom of page) and you will get emails ALERTS! of the additions.
I'll put the new stuff at the top of the list so you don't have to scroll more and more. No historical things and variant clones. Unless I think it is 8-), :idea: or :ugeek:
NOTE: Each is a snapshot of when the Thing was listed YOU need to determine whether a Thing is fit for purpose.
PREFERABLY wait for me to find new Things, but if you must...consider PMing me first...but, if you must
Post a Thing ALERT!, PLEASE don't include pictures etc (as they should be on the 'verse & they make this thread unnecessarily large), and
USE THIS FORMAT:
[url=<the Things url>]<The title on Thingivers>[/url]<. Additional description if Thing title is unclear.>.
If you update a Thing, PM me - rather than adding unnecessary posts - and I will annotate it.
If you must post with a transient meaning, please consider removing some text/images to clean it up it after a suitable period of time. Otherwise it quickly grows too large.
PLEASE Do not use this thread for discussion. As it will unnecessarily SPAM subscribers to this thread.
Discuss things at Thingiverse as then ALL the 'verse gets the benefit. Or PM the poster with a question.
This will likely be my last update here.
Dial Indicator for Printrbot LC and Plus
Modified Printrbot Simple Filament Guide with Marker Guide. "include this marker guide for coloring your filament while it's being fed"
Printrbot Plus, V2, CNC Router, 1/16in endmill. DXF for cutting with router
Printrbot Simple V2 40mm Fan Mount with Duct
Aluminium bed for Printrbot Plus (V2)
Machine-top spool holder for Printrbot Jr.
Printrbot No-Wobble Z Coupler
Printrbot PLUS/LC Z Isolator for M8 rods/nuts
Printrbot PLUS V2 Top Stiffener Bracket for M8 hardware
Printrbot Simple V2 Extruder Tensioner 40mm Fan Mount
Level Knob for PrintrBot Plus Aluminum Build Platform
Printrbot Jr Bed clip
Printrbot Simple Acme knob
PrintrBot Simple - Hinged Extruder drive fan mount for 40mm fan
Retainer clips for printrbot hot bed
20130901
Printrbot Simple Bench Mount
Printrbot LED mount
AC PrintrBot LC v2 X Rod Support Stabilizer
Printrbot Simple x-axis tensioner
Other half of Printrbot z-stop
Wood L&S gears for PrintrBot wood extruder. For laser cutting
Printrbot Extruder stl files. From Brooks DXF files of the wood extruder
PrintrBot Simple Plaque
C PrintrBot LC v2 X Bridge To Bridge Support. Interesting discussion re bowing effect of belt tension.
Printrbot LC v2 Extruder Tension Plate With Nut-Lock
Articulated Ball Joint Fan Mount - for printrbot GO
Printrbot Simple V2 Mods. Filament guide, fan holder & feet
Printrbot LC V2 Dial gauge mount
The Jr. Printr Cup v2
Printrbot Flashlight Mount
AC PrintrBot LC v2 40mm Fan Mount. (AC=author)
AC PrintrBot LC v2 Bearing Sleeve
Printr Cup - with nozzle holder
Belt Tensioner for printrbot GO - Y axis
Printrbot E3D Hotend Bowden Mount. "This carriage is designed as a bolt-on replacement for part of the stock Printrbot X carriage." For LC/+
Printrbot LC Y axis rod stabilization mod
Printrbot Simple Infinite (v0.1)
Printrbot Foot Rounded. Look like it's for Original
Printrbot Power Tower Modification for MatterHackers Filament Spools
Printrbot Simple Beta. "What results is a crude approximation of the Beta"
PrintrBot LC V2 - Quick fit X-Carriage
PrintrBoard compact cooling enclosure. " for the PrintrBoard Rev.E "
Printrbot LC+ Quickfit Z-Mount - Bowden extruder
The Jr. Printr Cup. Tool holder
part E1 for printrbot simple directdrive.
Z Indicator cap for Printrbot simple w ACME screw
Printrbot mini feet/stabilisers. Maybe the start of a new derivative??
Printrbot Simple Y axis string tensioner
Printrbot Dial Gauge Mount
Printrbot Hinged Spool Holder
Printrbot (Simple) bottom filament guide
Printerbot Jr Cable block. keep your bed cables from hitting the Z motor coupling
PrintrBot Foot. For a PrintrBot Simple
40 mm fan mount for Printrbot Simple V2
printrbot Simple string tensioner
Printrbot LC Z Axis Bolt Renforcement.
Printrbot plus V2 bed spring
PrintrBot Simple V2 Mods. PLA Feed Tube, Fan bracket, 30.5 mm flanged cap (spool hub), 8mm foot/elbow
A better tensioner for Printrbot LC v2. "much greater range of tightening and doesn't risk damaging your belt"
Printrbot Y Belt Tensioner V2
Mochaboy's "Tool less" Tensioner Printrbot Jr / XL belt
Printrbot Z-Spool+Stabilizer+Wobble. May want to wait for MkII
Holder For Printrboard. "with a place to hold down the USB cable with a tie wrap", I used hot-glue
Z Stabilizer Top-of-Rod Clamps (8 or 12mm rod). Like a top joindler
Printrbot Simple Extensible X-Axis. Note: I don't think the firmware referenced is suitable for Simple.
PrintrBot Jr X Axis Tensioner
Printrbot Plus V2 fan+LED holder
J-head adapter for Printrbot Jr
Printrbot Jr Extruder mounter. "mountint the printrbot exturder on Y-Z axies base , so that you can make the nozzle not so heavy"
Leaning Tower of Printrbot. compensate for the Y-Axis droop in a Printrbot Simple (Beta) ... a simple Perl shim script
Printrbot Simple Spool Holder. "Printrbot Simple" not "Simple Spool Holder"
Printrbot Plus (V1) Z Axis 5mm threaded rod upgrade
Printrbot Adjustable Fan Mount. 6cm fan version
Hybrid Wade's-Bowden Dual Extruder Mount for Printrbot
Printrbot Logo on X axis front plate
PrintrBot Plus V2 Corner Clip
Printrbot Simple Final 40mm Fan Holder. ie final version of Simple
PrintrBot Dremel Mount
Printrbot Simple Z-Endstop Activator holder
Printrbot spool holder "upgrade"
Printrbot Original Side Fan Mount. Clips on to the X motor mount
Printrbot Jr.'s other feet.
Filament Holder for printrbot GO
Printrbot Jr Vibration Isolator
Simple Printerbot LC Filament Guide
Printrbot jr filament spool stand
Smooth Printrbot+ Extruder Mount. w integrated fan mount
[20130701]
Printrbot Jr. Bowden Extruder Mount
PrintrBot Plus Spool holder
Printrbot Laser Cut Build Platform By Beardface. rotated & centered to fit A3 paper in landscape
Printrbot LC piece #150
Printrbot Jr Bowden Shaft Mount
Printrbot Wooden Spool Hub. well plastic hub for wooden spool...
Filament Guide for Printrbot
Printrbot Spool Adapter. to fit 8mm rod/dowel
Printrbot Simple Fan and LED Mount. ie simple bot not fan
Printrbot Depth Gauge / Dial Gauge Bed Leveling Mount
Printrbot offset z axis nut:Less Wobble!
Printrbot Helical Extruder Gears (Large & Small)
Printrbot Jr Fan Mounts
Printrbot Z isolator & mini-cnc adaptor. For LC
Printrbot Plus Vert. Shaft Extruder Mount for Bowden. Extruder on Z shaft
Ubis Hot End Bowden Mount (Printrbot)
Printrbot Simple Bed Leveling Screws. Simple and for the Simple
Printrbot Spool. Laser cut
Printrbot Plus V1 Z bar stabilizers
Milling Vise. Using Printrbot
Printrbot LCD Panel model. " that you can use as a starting point when working on mounting options."
PrintrBot Simple Z-Axis Limit Switch Mount - V2
PrintrBot Simple Deluxe Y-Axis Sag Fix
Printrbot Simple Anti Y Sag
Printrbot Simple 40mm (Mounting Hole Distance) Fan Holder
Bowden extruder - pneufit adapter backlash / oozing reduction ring. See the white ring around the chrome bit in photo 1.
Printrbot Simple Bowden conversion
Original Printrbot Z coupler. I'm assuming 'Printrbot Original'
Printrbot LC test pattern 100*100
Printrbot 24mm Fan Mount
Printrbot Simple Feet!. Simple feet are happy feet
Printrbot Z-stop thumb adjuster
Printrbot X Axis front plate. a replacement for the wood plates the V2 ships with
Printrbot Filament guide
Printrbot Z Axis 5mm threaded rod upgrade
Printrbot Bed Adjuster Knob for 4mm Bolts
Glass Clips for Printrbots - measured to include 2mm neoprene insulation
Printrbot Plus Quick-Fit Upgrade
Printrbot Simple Bowden Conversion
Printrbot Simple Power Connector Mount
[20130601]
Printrbot Jr M8 Z-axis upgrade. "upgrading to an anti-backlash setup with two M8 nuts and a spring" (remember steps/mm changes)
Printrbot Simple 50mm Fan Mount. "give you an extra 5mm on your Z axis"
5/16in to 5mm Printed Z-axis Coupler, Slip-on and Low-profile. "replace the vinyl tubing coupler that comes with the Printrbot"
Printrbot Simple Z-axis Knob, v3. Netfabb fixed version of v2
Printrbot Simple Z Coupler
Printrboard Standoff. ie spacer
Printrbot LC Extruder Idler Nut Keeper with filament guide. WIP, STL is not rendered, may have problems
Sponnets modified Printrbot base extra made extra wide
PrintrBot LC vibration damper
Z-Axis Knob for Printrbot Simple
Printrbot Jr. Heated Aluminum Bed. Eagle v6.4.0 layout and pdf files for creating a PCB heatbed
Printrbot Jr. Aluminum Bed. Used with above
Printrbot Simple Z-axis Knob, v2.
Printrbot Simple 40mm Fan Mount
Printer Brace and Spool Holder. "Stable printers are happy printer,"
Printrbot Simple z-coupler
Printrbot Simple electronics shim. "to give you about half an inch of extra space"
Printrbot Jr X Axis Tensioner set
Printrbot LC fan shroud / air control
Printrbot Jr. Bed leveler
Printrbot Jr. Bowden extruder. From the looks, could fit other bots too
printRbot y belt clip. Y? I don't know...
31.2 mm from hole to holefan mount for printRbot with pen plotter attachment
Carbon-Fiber Handle for Printrbot Simple
suitcase handle - for printrbot GO
Printrbot PLUS Glass Clips. "but will likely work with any printrbot with heated bed and 1/8" thick glass"
Printrbot Jr. 40 mm Filament Fan... (Adjustable! :D). Supposedly helps with filament jamming??? Know how? Tell all on Thingiverse.
Printrbot V2 Low-Profile ThumbScrew
Leveling Locks for Printrbot LC. " to prevent undesired rotation as the build platform jiggles"
Printrbot Plus V2 Z-axis nut holder
Printrbot Plus GT2 upgrade Belt clips. "to upgrade the stock belt to a GT2 belt... It holds the belt in place"
Printrbot Simple Z-axis Knob. to be able to make fine adjustments to the printhead height.
Printrbot+ Filament Spool Holder. Mounts on top of Z rods.
Printrbot Simple Spool Holder. Simpler version, for Plus.
Printrbot LC and LC+: Y Bearing Guide for GT2 32 teeth pulleys DERIVATIVE
printrbot GO - latch for front door. First GO Thing
Printrbot Jr. Z Axis screw setter - tighter tolerances
Printrbot Jr. / Modular, 80mm Fan Mount.
Pivot Lever Belt Tensioner
[20130501]
Printrbot easy removable Y-idler
Printrbot v2 wider X ends. "make the threaded rod axis to be centered to "NEMA17 48mm" 's shaft"
Printrbot Dual Extruder Carriage and Mount V2 for Linear Bearings. "Use this with my X Axis 3 rod addons"
Xbox 360 PSU Socket Housing for printrbot GO
Printrbot Enclosure. WIP, based on a sandblasting cabinet.
Printrbot LC Y-axis Extended Table: print in a 6x8 area! Laser cut pattern. You'll need longer rods, not sure if there is a 6x8 hotbed.
Nut Embiggenator (M6 to 5/16"-18). Fit a M6/Rod to your Z axis
Bolt holder for Z endstop on Printrbot Jr
Printrbot Z-axis Set Screw Tensioner mod. For PLUS, probably LC too?
Printrbot Z Support. "This is a 8mm Z Rod Cap / Bracket & L Bracket for use with Aluminum C Channel for a Printrbot."
Printrbot Dual Extruder Carriage and Mount. "3rd rod x axis brackets" to take the extra weight
Simple Printrbot Plus Filament Guide. For 12mm rods
Re-Upload: Japica Printrbot Base
Light Box for PrintrBot Logo
formerly Japica (PrintrBot derivat)
Printrbot Plus Z Stop Dial - 80mm with Pointer
Simple Belt Tensioner for Printrbot Jr -- GT2 belts
Printrbot Jr. Base Corner Pieces
Easy adjust bed leveling For Printrbot LC PLUS
Printrbot Nozzle Case
Printrbot 40mm fan mount for electronics. for LC
Printrbot LC Simple Fan Mount
Printrbot Jr. Snap-on Fan Mount
20130401
Printrbot Jr. Filament Guide adapter
Printrbot Helical Extruder Gears. To replace lasercut gears
Printrbot X Axis Belt Tensioner (No Zip Ties). for LC
smart controller mount for Printrbot LC PLUS. For RAMPS not Printrboard
Printrbot Jr bed leveller gear. More knob like
Printrbot Spool Holder. Sits on top of Z smooth rods
Printrboard support
Printrbot LC PLUS Bowden cable x idler mounting
Low Profile Glass Plate Clip. Not strictly a Thing
Printrbot Jr SD card holder
Printrbot jr. z axis improvement. 2 nuts 4 anti-backlash
Fan Duct Bracket For The Printrbot+ LC
Thicker and longer Y bar end for printrbot/wallace. "because the Y motor shaft otherwise hits bolts that retain the heatbed"
Beefier y-bar clamp for printrbot. "This allows you to have a rectangular build plate" ??
6 x 6 Inch Glass Bed Clips for Printrbot Jr. Interesting concept
Mount for power supply for original printrbot. The extra weight should keep the pb in place too, needs the following
Big Foot for original printrbot
Clip-on Printrbot brushless blower turbine fan mount. For LC
Big Zee Printrbot Lead Screw Isolator. Probably not a good idea
Printrbot Jr. Belt Tensioner
PrintrBot JR LED Mount
Printrbot Jr. Filament Guide (1.75mm)
Printrbot LC Filament Guide
Paste extruder for printrbot
Printrbot Jr. Z Stabilizer. Not good to constrain z-threaded-rod IMO
Printrbot Z Hack. M6 threaded rod a pair of captive nuts and a spring. printed adapter
Printrbot Jr. Acrylic Printbed. lasercut from 6mm sandblasted or textured acrylic
Printrbot+ Micrometer Z Adjuster. Inspired by an original design by Plexus
Printrbot PLUS Z-axis Set Screw Tensioner
Printrbot LC Isolation Mount
PrintrBoard Mount w/Fans. "This mount was designed to mount to the side of my Prusa Air i2" not strictly printrbot, but close.
Y-Rod Printrbot Jr. Handle
Clips for holder printrboard at printrbot original
Printrbot lc Extruder washer. Keep your extruder clean, no the other type of washer
Printrbot Top Joinder w Nut Retainer & Y offset. TaDaah
Printrbot Spool Plug by Eirinn
V2.0 Printrbot + Upgrades. By PolakiumEngineering, not Printrbot
Printrbot + glass clips for window glass
20130301
Printrbot Z Axis Stabilizer. "Designed and tested for a Printrbot LC, though I believe it'll fit a Plus model as well."
Printrbot jr folding bed clip. "Extra clip to hold bed of the Printrbot jr on outer side."
Koch Printrbot bed leveling system. LC y-ends with springs
Printrbot LC Clip on Fan 70mm
Holder for printrboard at original printrbot
Printrbot Z axis stabiliser
adjustable printrbot x-axis tensioner
Front Mount for Glas or PC on heatingbed printrbot.
Rear Mount for Glas or PC on heatingbed printrbot
Printrbot Nozzle Fabrication Toolbox. Printed parts to make a nozzle, with a very good video
80mm Fan Mount for Printrbot Jr.
Printrbot Wood Extruder Gear. "Who doesn't like the biohazard symbol?"
Printrbot foot. And stepper stabiliser
printrbot plus w RAMPS1.4
Printrbot Jr. 40mm fanmount with LED
Printrbot XL Mod. Super-size me
Ovals-be-gone! Y-belt tightener for Printrbotby SVAPS. Very nice solution
Printrbot Z Drive Clamp. Yet another coupler
PrintrBot Jr. - Print Bed Adjustment Knobs and Pegs
For printrbot thermal sensor mount. I'm amazed nobody though of that before
Z knob retainer for Eckerput's Z knob for Printrbot
Printrbot LC X Axis Stiffener. "belt tension causes the X bridge to warp. This brace is designed to counteract the warp"
Printrbotter Official Pen. I'm not sure what makes it 'official'
Printrbot 10 Tooth Pulley Mod. For D shaft steppers
Printrbot Plus Pivoting Fan Mount
Printrbot Y-Axis Mod. Added steroids
Z-Stop Adjuster for Printrbot LC
PrintRbot LC in the Ponoko template
Printrbot Jr. 40mm fan mount
PrintRbot Y belt Tensioner
Printrbot Fan Bracket - 60mm
Printrbot LC 40mm fan mount with LED holder
Printrbot Top Z Axis Stabilizer. For Original, LC & Plus
PrintrBot LC small extruder gear. Cleaned up. Should do other models too
20130201
Printrbot LC 40mm Fan Mount
Printrbot cable chain X-motor mount with connector.
LC 40mm Fan Lite. Probably OK with Plus
PrinterHome. 'home for your PrintrBot Original or LC, but not plus, its accessories and tools'
Printrbot Jr. Lasercut files
Triple Fan Mount for Printrbot Jr. (Version 2)
Printrbot Z stabiliser with power switch and indicator
Printrbot Pen Holder (Repaired)
Printrbot Bed Stabilizer. 4 LC, possible Plus too?
Printrbot PLUS Precision Bed Leveler
Adjustable bed for Printrbot+. WIP, needs instructions/pictures
Printrbot LC Idler with 3mm filament guide. Should work on all Pb's
Printrbot Jr. X axis belt tensioner
Printrbot + LC spider coupler. Should work for Pb Original, intersting use of silicone.
Printrbot LC X-Axis Stabalizer.
Printrbot Z-Axis End Stop Nut Keeper. For LC
Simplified Printrbot Spur Gears
Printbot+ X-Carriage. For the Printrbot+, featuring an integrated fan mount.
Printrbot X Axis Belt Tensionr
printrbot open cable chain
Printrbot Jr 80mm fan bracket. "it will make your Prinrobot Jr look like a Mazda Miata with 4 ft spoiler. Do it."
Shorter Printrbot Plus LC Filament guide. shorter to save some plastic
PrintrBot name tag
PrintrBot Plus Z Screw Isolator
Printrbot LC side fan mount
Printrbot Jr Y Axis Belt Tensioner
Printrbot LC Z Stop Dial
20130101
Printer Enclosure Cut List (Parametric)
Filament Pass-Through (Parametric) using Old Wiper Blades as a Seal. For LC enclosure
Vertical Board Anchor (Parametric). Hold your LC/+ feet, could be moded for Original
LED Holder for PrintrBot. For LC & presumably Plus.
printrbot cable chain stepper mount.
Printrbot idler latch with 3 mm filament guide and captive nuts (hexes rotated)
LED Ring Mount for Printrbot
Filament Guide for Printrbot Wooden Extruder
Printrbot PLUS Bed Leveling Mod
30mm Printrbot Fan Mount. To fit on a Printrbot LC wooden extruder
NO Glass Clips for Printrbot-solution
PrintrBot+ Glass holder for IKEA Sörli mirror
PrintrBot Plus Illustrator, PDF, and SVG files
Z-rod stabilizer for Printrbot PLUS
80mm Diablo Fan Mount
Printrbot Z Bar Stabilizer Set. For LC Plus
Printrbot Wooden Spool Hubs
Printrbot Jr Rod Brace / Carrying Handle. "Keep in mind that this device doesn't really serve any real purpose", danimal added "The rods don't need any bracing but I realized you could use it as a handle."
X-End Stabilizer for Printrbot
Printrbot Printable Bed Frame (shorter version)
Wersybot - a derivate of The Printrbot. "My intention was to be as close as possible to the original parts but with some improvements."
20121201
Printrstand - ziptie edition
Printrbot Z stabilizer. This piece helps the stabilization of z Motors of your printrbot. I don't know where it goes...
Z-Axis Double Rod Stabiliser for Printrbot
Printrbot LC Switch Mount
TentRbot - PrintRbot plastic hanger tent attachment
Carrier to carry the Printrbot. For the Original
and I seem to have missed some lately, sorry...
Simpler Top Stablizer for Printrbot
Circular Fan Duct with Holder for Angel Eyes. will need to ask for his other bits
Spur gears for Printrbot Wood Extruder
50mm fan air duct. I think for LC/+ only...
Clip-on Printrbot 40-mm Fan Mount another version
DIY Printrbot Hinged Spool Box
20121101
PrintRbot Top Joiner - Plastic Cross Beam.
printrbot lc hotend protector
Printrbot v5.0 Extended - The best printer in the USA. <- that's what he said, not me. Seems to be radically different to Printrbot, just similar geometry.
printrbot dial mount. For LC extruder
Printrbot 2.0 Derived + 20x4 LCD Controller (WIP)
Printrbot LC Single Universal Extruder Mount.
Power Tower. He designed a version from scratch
Printrbot with J-Head and Ubis Mount. Ripoff (sorry derivative) of the LC Printrbot
Parametric Printrbot Parts. Files in asm/par or stp
20121001
Printrbot LC fan mount (laser cut)
Printrbot Extruder. The new laser cut one.
Printrbot Plus. "This newest version includes laser cut bar ends and belt clips."
PrintrBot Plus simple filament guide
Printrbot + Upgrades [X-bridge, Extruder Mount, Y-Clips]
Printrbot LC X Carriage Printed Part Conversion
belt tensioner - T5 - made for a printrbot on Y axis
Printrbot+ Filament Guide
Printrbot+ captive nut keeper
ExtrudrPlate - Printrbot Extruder Tray
PrintrPlate - Printrbot Full Build Tray (On Steroids)
Another 40mm CPU Fan Mount for Printrbot LC+
LED light holder for Printrbot+ and LC
PrintRbot nema17 Z endstop box
Printrbot compact X carriage Jhead Mk-V & gregfrost extruder
Micro Engraver PrintRbot / Wade mount. for mounting on laser mount (see below)
Printrbot+ LC control panel
Printrbot Original Build Platform
Printrbot+ Nutkeepr
PrintRbot Laser Mount
Printrbot idler pulley with 18 teeth.
3D printed PB spool stand
Printrbot LC Bowden Cable mod
Printrbot X Axis Belt Tensioner. For LC & LC+ I think?
Printrbot Glass Clips
PB Spool Stand
Printrbot Y Axis Belt Tensioner
Printrbot LC+ X-nut Keeper
printrbot glass clip modified
PrintRbot X Carriage Display Stand
PrintrBot Extruder Measurement Tool
Clip-on Printrbot 40-mm Fan Mount, Version 2
Spur gear for PB Wooden Extruder
Printrbot Part 104 replacement LC+
Printrbot Longer Y Axis Belt Clips
Printrbot Toggle Power Switch Mount
20120901
Hotend Fan Mount 50mm for Printrbot
Printrbot hotend adapter v2
Printrbot X Nema 17 fan mount
Dial indicator holder for Printrbot
The best X-end pieces for the Printrbot - easy exchange rods and sturdy
Printrbot cable hook.
608 carriage for the Printrbot by Japica
Raj's Extruder MK1 for Printrbot
Fanbox for Printrbot Air Nozzle System
Printrbot Aluminum. CNC cut
Short Printrbot extruder gear
Printrbot LC+ Fan Mount & Fan Cone. (LC & Plus) May also work on Original(?)
Printrbot LC any Hotend Huck. I think they mean HACK.
Printrbot (Updated) extruder fan bracket in mm. ie Metric
Clip-on Printrbot 40-mm Fan Mount.<Obsolete: See [url]Derivative[/url]>
Printrbot base with z-motor support.
Printrbot alternate Y axis. Mounts the stepper motor horizontally, use bought pulleys otherwise too large to mount vertically.
Printrbot Printrboard cooling fan bar mount
Printrbot basic cradle.. So the core of the printer can be removed and replaced in the same location on the work surface.
Printrbot 80mm fan mount
Printrbot anti-wobble.
Z-axis parts for trapezoidal spindles for the printrbot. Occupy victim.
Printrbot X idler pulley
Stronger E-idler for printrbot
Printrbot Fan Bracket & Duct
Printrbot Spring Loaded Bed Leveling System
20120801 - I'll try to remember to insert these periodically
Printrbot LC/plus fan mount
"Bearing" for Printrbot filament guide thingy
Printrbot Power Extension. For LC
Printrbot LC+ filament guide thingy
608 bearing Printrbot Base - NEW V4.0
Quick-Fit X Carriage for @Printrbot LC
Printrbot LC Plus Adjustable bed leveling nut lock
Get-Rid-Of-Belts-On-Printrbot-Thing. Rack gears
Printrbot Wooden Extruder Bushing
Printrbot LC+ No-slip Foot
Easily Adjustable Printrbot Glass Clips
J-head Adapter
x carriage for printrbot. less wobbly x carriage with 4 lm8uu's ..
Printrbot-inator
Printrbot LC+ Heated Bed Clips Side & Front
Printrbot Bowden Cable mod
Printrbot MEGA-Z Mod.
Printrbot y-belt clip alternative.
Printrbot Y Bar End w/ Nut Trap
Printrbot modified parts. X Motor Idler & Carriage.
Printbot LC 50mm Fan Mount
Printrbot LC Z-Axis Steppper w/ Acme Screw
Printrbot+ and LC printed Extruder Mount
Printrbot LC Plus Z-Endstop
Ybar end bed mount. A mount that had a larger mating surface.
Printrbot Base In Two Parts. To reduce warping.
Printrbot + y axis belt bracket tensioner
Universal printrbot electronics ziptie mounting hook
Another Printrbot Glass Clip (4mm glass)
Spur Gears for Printrbot Extruder
PrintrBot LC Foot Pad
Printrbot Lasercut Spool. The Original one.
20120701
Printrbot Z-endstop printed replacement
Drew's Printrbot YBar Ends
Dual rods printrbot
Smaller Printrbot rods end hat
X-Mount & X-Carriage derivatives of the original PB things, also Fan Mount & Stepper mounted 40mm fan mount (thanks scantrontb)
Printrbot Printrboard mounting bracket
Printrbot adjustable heated bed
Quick-Fit X Carriage for @Printrbot - OpenSCAD
3d printable lc plus parts for printrbot plus
PB + extruder mount
pbot parts - apparently Printrbot LC parts STLs for printing in plastic. No longer exists.
Printrbot Z-Axis Stabiliser + Filament guide COMBO
Printbot extruder mount with fan.
Printrbot LC Fan mount
Z Motor Brace
Filament pully for a printerbot
Printrbot LC part cooling fan mount
Printrbot filament guide thingy. Occupy Thingiverse victim. See instead.
Printrboard box
printrbot fan mount
Quick-Fit X Carriage for @Printrbot - #30DoC day 5
20120601
PrintrBot Killswitch Mounting
Printrbot Rod Cap & another version Printrbot Rod Cap (Bulb)
Printrstand
printerbot x axis spring
Printrbot Z-Axis Stabiliser Ends. Styled to match Brooks design.
Printrbot Original - NEW Version of some parts. 27 May, Some new parts as shipped. Extruder w gears, pulley, coupling.
_ (STL for pb-X-Carriage-w-Z-endstop - missing from Thingiverse, is below. Thanx Arvin.)
_ (STLs in ZIP files are avaialble here)
Printrbot LC
Improved Printrbot Endstops
Printrbot Z axis microswitch poker.
Printrbed bot standoff and glass clamp
U-clamp for securing printrbot. eddiema's not gona drop his bot again ;)
xt60 DC socket mount for printrbot.
Printrbot Base, with extra supporting lip & stopswitch support Missed this one sorry :oops:
Printrbot Fattened Y Bearing Guide
Parametric Printrbot Logo
Printrbot-Plotter Marker Mount
Hugo A Printrbot derivative
Glass clips for Printrbot
pb_z_end_stop
pb-Y-BarEnds-mod.stl
printrbot Y-bar-end with Y-end-stop trigger
printrbot Z-end-stop holder
^ Things since 1st May 2012. Newest on top.
v Things prior to 1st May 2012. In order of the Thingiverse seach results, sort of...
It all started with THE Printrbot. Brook updates this, so it is always worth a look.
I'm trying to get the other things needed which aren't on THE Printrbot page. NOTE:The historically missing parts were subsequently uploaded to the Printrbot Original (above).
These MAY BE the items, let me know by PM if you have better candidates. Edit/ see New Version above for most parts /edit
Herringbone Gears for Gregs Accessible extruder may not be Printrbot version :?: looks right. WRONG
Yet Another Prusa Mendel Z Coupling
Greg's Hinged Accessible For MG And J-head Hot Ends With plain gears.
Parametric Herringbone Gear Set for Greg's Accessible Wades
Symmetric Prusia Z-coupling. I think these are it but for M3 20mm, Brook may have moded these for Imperial nuts :?: Or
Yet Another Prusa Mendel Z Coupling. Alternative.
Other Printrbot related stuff;
Printrbot ID with numbers Label your bot
Printrbot rods end hat Good to stop taking your eye out :shock: (may rub on motor @ high Z left X)
Wider PrintrBot Base and 12mm Z axis, Stylized by morrisgunn
Printrbot Full Build Tray Note: these are not the updated parts. Thanks FisHNorway.
Printrbot Fan Mount
Printrbot Printable Print Bed
Printrbot Lasercut Print Bed
Printrbot Side Fan Mount
Alternate Printrbot Base
Printrbot Hotend Adapter
3D Printer - Heated Bed Tabs to hold down glass or this or this. Not really Printrbot, but may be handy.
Curvy Coin-Op Bottle Opener The Printrbot Kickstarter Reward.
That's it. If anyone wants any more historical items added PM me with the Thing number.
______________________
The following is from a post below when I reacted to innocent posters discussing Things.
However, as I'm assuming that we will get many Printrboters subscribing to this thread, I have moved it up here. Just try to be considerate of the subscribers.
I realise I'm breaking my own rules... but so we don't get Thing ALERTs going off all over the place can we please t r y to keep Q & A's away from this thread.
Please use the Thingiverse 'comments' to discuss a Thing, that way everyone in Thingiverse gets the news, and everyone subscribing to this thread doesn't get blasted.
In my priority order;
a. Wait for me to notice a new Printrbot related thing, I have no life so I check regularly, (If you see me slacking PM me)
(The advantage is that I will batch up multiple new Things hence minimising ALERT emails)
b. PM me if you think I missed a relevant thing,
c. IF your thing needs special explanation that you didn't/don't want to post with the Thing, post a reply here with your details,
d. If you really can't wait, post your Thing ALERT,
e. When you do post, and after your post is no longer relevant once I update the OP or is no longer timely, delete your post if you can (no replies) or edit to shrink your posts,
f. Ignore my efforts to keep this thread relevant and minimise the emails to subscribers of this thread.
Sorry, I do not mean any offence, but I'd like to keep this as clean and relevant as possible.
edit Toned it down a bit... Sorry :oops: /edit
_________________
  • 3
ImageKickstarter original. ** See all Printrbot Things in one spot HERE! <- I try to keep that thread compact, please assist by deleting transient posts
Michael@Oz
Re: Printrbot Thing ALERT! New Thing Found!
Postby eddiema » 2012-May-Tue-00-May
Michael@Oz wrote::idea: I think we need a thread where people can post when they see a new Printrbot related Thing in Thingiverse. So here goes, for your making pleasure...
(When I have time I'll try to add found Things to this first post. I'll put the newstuff at the top of the list so you don't have to scroll more and more.
Slowly adding older Things.)
Thanx,
I was going to design the exact same thing - although the hole on this one looks a little low for mine.
My switch hits the gap and just below it.
Good timing.
eddiema
Aluminum coupler brain
Postby eddiema » 2012-May-Tue-05-May
eddiema wrote:printrbot Y-bar-end with Y-end-stop trigger
This would work better for me.
I'm not happy with how it slices ATM. It seems not fill properly around the 3mm hole.
.stl files aren't allowed here. Unless someone wants it sooner I'll wait till I've tested it before uploading it somewhere.
edit: Changing slicer fill from rectilinear to line seems to fix my fill problem.
eddiema
Postby eddiema » 2012-May-Tue-07-May
My y-end mod in skp and stl can be found here.
Along with the skp port of the ZEST.
None are tested. Don't hotlink to the files because that will fail.
You can copy or post them elsewhere if you wish but wait till they are tested.
http://nerdipedia.com/tiki-list_file_ga ... lleryId=17
eddiema
Postby eddiema » 2012-May-Tue-12-May
I've stuck my ZEST sketchup port and my Y-bar end mod on ThingyVerse.
http://www.thingiverse.com/thing:22358
http://www.thingiverse.com/thing:22357
eddiema
Postby karmacappa » 2012-May-Tue-12-May
AFAIK, the herringbone gears are not designed by Brook. He seems to have used these:
karmacappa
Postby CL1 » 2012-May-Tue-20-May
Michael@Oz wrote:OK, I put the gears in the top post.
Anyone finding the other non-Brook things PM me and I'll add them. Shaft couplings, ...
As I've mentioned in other threads, even the *borrowed* parts have been modified. Some rather significantly. These that you're finding may work, but they are not the same as as was shipped. Brook needs to release the updated parts to Thingiverse. If enough backers request it by writing to info@printrbot.com , it might happen sooner?
CL1
CL1
Can update firmware
Postby pocketscience » 2012-May-Wed-23-May
xt60 DC socket mount for printrbot:
http://www.thingiverse.com/thing:23217
printrbot backer #147
pocketscience
Postby pocketscience » 2012-May-Thu-00-May
U-clamp for securing printrbot:
http://www.thingiverse.com/thing:23219
pocketscience
Postby eddiema » 2012-May-Sun-03-May
I've added another thingy to my TV page.
It is a 6mm standoff with a few different sized clamp parts.
http://www.thingiverse.com/thing:23387
You can also see my etched glass and depron insulation.
The old depron was heat damaged but I don't intend to ever run it that hot again.
eddiema
Postby Alexmadsen1 » 2012-May-Tue-21-May
Cable Chain and Brackets for PrintrBot
http://www.thingiverse.com/thing:23552
Alex
Alexmadsen1
Postby pocketscience » 2012-May-Fri-22-May
pocketscience
Postby Arvin » 2012-May-Tue-05-May
Michael@Oz wrote:Printrbot Original - NEW Version of some parts. 27 May, Some new parts as shipped, including Extruder, gears and couplings.
Have you gotten the STL for pb-X-Carriage-w-Z-endstop? Noticed on thingiverse you were asking for it. I just converted it to stl in sketchup. I've zipped it up.
Kickstarter backer #517 [standard printed PB]
Arvin
Postby Michael@Oz » 2012-May-Wed-18-May
ken schmitt wrote:has anyone retrieved them all and have a zip of this set?
ZIP of STLs - unfortunately the forum has a file upload limit so I had to break it up.
The extruder gears are too large, download them from Thingiverse Printrbot Original - NEW Version of some parts
If anyone has downloaded the Sketchup files, feel free to post a ZIP.
Or all in one ZIP here thanks to Ken
[Note: This post is linked to from external sites - don't delete]
Michael@Oz
Postby Michael@Oz » 2012-Jun-Tue-19-Jun
edit If you got here congrats, but from now on it is just the individual notices for each Thing found. If you read the Original Post then you have seen everything... /edit
Michael@Oz
Postby shai » 2012-Jul-Tue-14-Jul
I made a printrbot LC switch mount. You can view it on Thingiverse here: http://www.thingiverse.com/thing:26193
Backer # 1,612
shai
Postby drawcut » 2012-Jul-Wed-12-Jul
drawcut
Postby Michael@Oz » 2013-Feb-Sun-21-Feb
And while it is not Printrbot specific, I though this was neat Very easy cable organizer.
Michael@Oz
Postby Michael@Oz » 2013-Feb-Tue-01-Feb
Michael@Oz
Postby plexus » 2013-Feb-Tue-11-Feb
Michael@Oz wrote:For printrbot thermal sensor mount. I'm amazed nobody though of that before
You are going to press a piece of ABS up against a very hot print bed heater trace? that should make for an interesting blob of ABS and a messy, likely damaged print bed.
There is this new thing:
Postby FineAirDE » 2013-Feb-Thu-03-Feb
Hello Plexus,
working temperature of ABS is max. 85 to 100 °C. My heated bed once was max. 70°C.
ABS is o.k. for this.
You press not the heating bed, you press the thermal sensor, the ABS ist not directly at the bed.
I take Poly Carbonat (PC = Lexan) at the bed that the ABS holds perfect.
First layer temperature I test in the moment 50 to 60°C.
Second and later layer 20
After printing you can take the piece of PC from the bed and take the part away.
schrotti
FineAirDE
Postby Mochaboy » 2013-Jul-Tue-15-Jul
This is really useful. Would it be possible to split up the list into parts by model? Including a section for universal parts?
Printrbot Jr born 6/13
Brass M8 Threaded Z Rod
Tool less belt tensioners
Aluminum print plate
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Michael@Oz » 2013-Sep-Tue-00-Sep
Anyone should fee free to start a phase II thread if they think it is worth it, but I note lots of people are using the Thingiverse Collections now, so these posts may be redundant.
Michael@Oz
Postby mikemwa53 » 2013-Sep-Tue-02-Sep
I myself look forward to this thread. I make it to Thingiverse as often as possible but even then I miss some Printrbot things.
Sooooo much to do
Sooooo Little time!!!
Montgomery, IL. USA
mikemwa53
Postby Michael@Oz » 2013-Sep-Fri-00-Sep
Michael@Oz
Postby MSEIF » 2013-Nov-Fri-05-Nov
I myself look ahead to this line. I create it to Thingiverse as often as possible but even then I skip some Printrbot factors.
Best Web Design Service in Norwich, UK
Norwich Web Design
MSEIF
Postby DonaldJ » 2013-Dec-Sun-03-Dec
Just uploaded a new thing: Magnetic fan mount for PB+
http://www.thingiverse.com/thing:204202
DonaldJ
Postby DonaldJ » 2013-Dec-Wed-09-Dec
Tool caddy with small parts tray:
http://www.thingiverse.com/thing:212687
DonaldJ
Postby Palerob » 2014-Apr-Sat-19-Apr
Metal Simple Spool holder.
Printrbot Simple Metal Spool Holder
A Simple is not just a tool, it is an addiction. ;)
2014 Simple W/ XL+Tower Upgrade
MODS: Jon's GT2 X and Y Belt mods, soon to have the Y extender and X Depth extender.
Also: 2014 Black Metal Simple (Technically the wife's but you know...)
Palerob
Postby Palerob » 2014-Apr-Mon-15-Apr
New Thing alert!
Printrbot Simple Extended Extruder Plate
Description
If you modified your Simple using Jon Lawrence's excellent Belt Drive X-axis Upgrade (if you flipped your bed mounting plate so the tabs are now forward) then you lost about a half inch of available printing space in the Y axis. This Extruder Plate adds 15 mm to the Y axis and your prints should be just about centered. I have added it to a 2013 SImple with XL upgrade (aluminum exturder) and a 2014 Simple. Works fine on both.
Palerob
Postby Palerob » 2014-Apr-Mon-17-Apr
Printrbot Metal Simple Filament Guide
Description
Filament guide for printrbot metal simple. If you are using a printrbot simple metal then I recomend you use the GCODE.
Palerob
Postby Michael@Oz » 2014-Dec-Fri-05-Dec
Sorry, about late posting:
A new unprintable seasonal thing
Michael@Oz
Return to Things talk
