Printrbot Talk Forum • View topic - My Printrbot+ (with trimmings)
Postby plexus » 2013-Apr-Fri-21-Apr
Lots of mods. too much to list.
Re: My Printrbot+ (with trimmings)
Postby holmes4 » 2013-Apr-Sat-07-Apr
An interesting mount for the Viki. I was wondering where I was going to put mine. How do you have it attached to the rod?
Steve
PB+ Backer 1402
holmes4
Bowden extruder
Postby Mooselake » 2013-Apr-Mon-14-Apr
Aging eyes want to know, seems things just aren't as bright as they used to be :)
How well does the under-bridge lighting work? I ordered one similar to yours, but it came with 3 dead LEDs (seller immediately shipped a replacement which hasn't arrived yet). Are you happy with where it's mounted? Is it too close to the bed on lower layers?
Postby plexus » 2013-Apr-Mon-15-Apr
@holmes its just one from thingiverse. i cut notches in it for the threaded rod and used washers and nuts to hold in place it moves around a bit which is ok because i can aim it at my face depending on if i am standing or sitting
@moose i actually have the strip on both the bottom facing edge of the X bridge wood and on the front. i use black tape the mask the front facing LEDs so they aren't beaming directly at me but provide some forward emitted light to compliment the downward emitted light from the other strip.
Postby holmes4 » 2013-Apr-Mon-15-Apr
Can you link to the Thing? I searched TV for "viki" and the only thing that turned up was some sort of metal mount for a different printer.
Steve
PB+ Backer 1402
holmes4
Bowden extruder
Postby plexus » 2013-Apr-Mon-21-Apr
Postby Dick Brewster » 2013-Apr-Mon-22-Apr
How are the Oldham couplers working for you? Where did you get them?
Backer #30 Lincoln California, Home of the Printrbot
Dick Brewster
Layer 100 of 1234
Postby plexus » 2013-Apr-Tue-13-Apr
Postby REPRAP SQUAD » 2013-Apr-Sat-11-Apr
I think my next few upgrades are going to be acme rods, spider couplers and my z axis motors. I had smaller z axis steppers but I ended up taking them off because they were not up to my standards. They were real slow and low torque. I like your Vicki setup plexus. I've used spider couplers in the past for my desktop cnc and they are the best option out there for the price. Thanks plexus for the great post on your printrbot. I always like seeing what other people are doing with their bots. Happy building guys!
Postby pkreitler » 2013-May-Fri-15-May
Plexus. What do you use to capture the x-bridge nuts that ride on the z-threaded rods? I am using wing-nuts with the x-bridge resting on them. They seem to work ok, but I'm not sure if there is a better solution.
pkreitler
Postby plexus » 2013-May-Fri-16-May
Postby pkreitler » 2013-May-Fri-20-May
Isn't it necessary to capture the nut to some degree so turning the threaded rod doesn't result in a spinning nut as well? The x-bridge must rest on the nut to prevent it from falling. Perhaps I should rephrase my question. Within the nut-box at each end of the x-bridge, do you have anything special to keep the nut from spinning and the x-bridge from falling? Or, do you just have a nut sitting in there. On my PB, the right side of my bridge had the nut "captured" by the two small slots on the bottom. On the left side of my bridge, the nut would slip because of a defect in the wood. I replaced the nuts with wing nuts that fit into the slots to prevent slippage.
pkreitler
Postby plexus » 2013-May-Fri-21-May
On my PB+ the laser cut design already accounts for this by making the channel slightly larger than the flat-to-flat width of the nut; there are two channels cut out of the wood to make room for the points. this keeps the nut from turning.
Postby plexus » 2013-May-Sat-00-May
Here's another shot. im doing a presentation for my client in Dallas next week and will show pictures of the printer and a few home projects where I did repairs with the printer.
Postby Arvin » 2013-Jun-Sat-08-Jun
Hey plexus. Like the look of the stained wood. Wish I had finished the plywood bed on my printrbot. I will when I change the y belt. If it ever goes bad like the x did. I replaced it with GT2 and new pulley as well.
I see you have the viki on top. Did you ever get it to work for printing? Mine's still nicely wrapped and sitting here looking at me sadly. I was hoping you or someone else would get it working and post how!
Kickstarter backer #517 [standard printed PB]
Arvin
Return to Showcase
