Mooselake wrote:Since you have the actual temps you could adjust the values in thermistortables.h rather than trying to approximate new ones with a script.
Impressive work!
chris wrote:plexus - so you are still using a custom fw build? Wouldn't it be a good permanent change to allow an override of key constants if a certain file is present, or maybe boot parameters?
I'm a little confused, in the end did you decide 250 was high enough (which the regular fw allows)?
chris wrote:I'm actually just saying wouldn't it be better to make it so that frequently changed things don't force a recompile. I guess noone else sees the value in that?
lwalkera wrote:I believe there is a python script in the Marlin source to regenerate the temp table it uses to linearize the thermistor readings.
calex_fr wrote:Hi alls,
I am french and I have a Simple Metal Rev D with new hot bed upgrade, and I have a problem.
In Repetier I confugure hot bed to 60°C but in reality I have 50° mesured with my infrared thermometer, does it normal ?
Users browsing this forum: Google [Bot] and 0 guests
