3D Printer Filaments PLA Gradient color
This forum is for people and companies that are selling supplies of interest to 3D printer users ONLY.
Re: 3D Printer Filaments PLA Gradient color
Postby RetireeJay » 2015-Jun-Fri-08-Jun
Wendy, please delete this post and put it in the "Marketplace - 3D Printing Merchants" forum instead.
Postby PxT » 2015-Jun-Fri-13-Jun
[MOD NOTE] Post has been moved.
Return to 3D printing merchants
