Mid-Year Sale on Aliexpress
This forum is for people and companies that are selling supplies of interest to 3D printer users ONLY.
Re: Mid-Year Sale on Aliexpress
Postby RetireeJay » 2017-Jun-Mon-05-Jun
If this post is to be allowed on the Printrbottalk forum at all, it needs to be in "Board Index", "Marketplace", "3D Printing Merchants". I have moved it this time. Future posts from this source will be deleted if they are not in the correct sub-forum.
Postby Mooselake » 2017-Jun-Mon-06-Jun
You're nicer than I am. This looks like Wendy (likely a house account, not a specific person) using another user ID
Return to 3D printing merchants
