Printrbot Talk Forum • View topic - Metal Plus Height Limitation with Dual Extruder
Postby JonS » 2015-Jan-Tue-05-Jan
There is kind of a height limitation on the Metal Plus with dual extruders.
I just printed a 247mm high vase (it has to be done) and when the x axis tried to home, the left extruder hit the black z bar top piece.
A quick check shows that this will take nearly an inch (22mm to be more precise) off the build height. Or, the user will have to remove their print, lower the z carriage before homing x!
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Re: Metal Plus Height Limitation with Dual Extruder
Postby Mooselake » 2015-Jan-Tue-07-Jan
Maybe change your end of print gcode, or the preset in Repetier-host, to move it to a "safe" position?
Postby JonS » 2015-Jan-Wed-02-Jan
- Heated bed
JonS
