Printrbot Talk Forum • View topic - Metal Plus Problems
Metal Plus Problems
Metal Plus Problems
Postby JonS » 2015-Jan-Sat-17-Jan
I was printing successfully with my new Metal Plus. Then last night I tried to print something close to the maximum x/y size and started getting in to trouble.
I was having problems with my bed leveling at high negative Y (front of the bed). This morning I started up again and read a thread on here that said to insert a G29 code for auto-leveling. I did that and it seemed to work.
I tried to print a 20mm cube and found that I'm getting garbled X moves. Firstly after completing the skirt it does a ~1cm move to the left and back again. What I end up with is like in this photo.
I've tried restarting Cura and progressively slowing down the serial comms baud rate. No difference.
Next, while doing this. I stopped the machine to clear off the failed print and sent the extruder back to X=0 and Y=0 and got a terrible noise. To my horror I saw the extruder has scrapped along the bed, destroying my Kapton film the process! I had sent no codes to change the Z-height. This should not have happened.
What's going on here? And once I resolve this, how do I get Printrbot to sent me a replacement Kapton film? (As an aside the film application on the bed is very poor. I know this isn't easy, but the number of large air bubbles is excessive.)
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Metal Plus Problems
Re: Metal Plus Problems
Postby JonS » 2015-Jan-Sat-18-Jan
[Update]
I tried changing my USB cable, recalling that the one that shipped with my Printrbot Jr was defective. I'm now using the cable that I've been successfully using with my Jr for 18+ months.
I'm still getting spurious moves. I just had another extruder crash situation that's left a bad score in my aluminum bed.
I already to remove the Kapton and replace it with a double layer of blue tape (how do you even change the bed leveling using Cura? It's unacceptable that Printrbot only has instructions on their site on leveling using Repetier having switched to Cura), but the crash scored straight through to the aluminum.
I'm not at all happy.
- Heated bed
JonS
Postby musk » 2015-Jan-Sat-19-Jan
If you use g29 bed leveling during a print, the z axis is constantly moving up and down to compensate for the tilted bed. In practice this means that if the back of your bed is high and the front is low, the z axis will move slowly downward as the nozzle reaches the front of the bed and will rise upward as it prints toward the back of the bed.
If you stop the print, auto-leveling turns off! If you choose to stop the print when the nozzle is in a "low" position (near the front of the bed in this example) and then proceed to manually move the nozzle to the back of the bed by using the buttons in cura or repetier-host you'll likely gouge into the tape and plate because the machine is blindly following directions to move to the back of the bed, without special instructions to raise the nozzle to compensate for the bed tilt. To avoid this problem, move the nozzle up a little bit before moving when the nozzle is so close to the bed. This issue does not occur after the first few layers because the nozzle is already high enough to avoid scraping the bed.
The good news is that the scrape in your plate doesn't really matter and you don't need a replacement.
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Postby JonS » 2015-Jan-Sat-19-Jan
Thanks musk! That tells me why the bed crash is occurring, which is a big help. It also tells me that auto-leveling is no substitute for real mechanical leveling (at least not with today's "dumb" manual moves).
Now I need to work out why I'm getting spurious moves. Any ideas?
- Heated bed
JonS
Ah! I've found out what the problem is.
I'd reduced my bed size to 7 7/8-inches to allow for the max. size for dual extruders. Then when trying to print something the full bed size, the extruder was off the edge of the bed by ~15mm. I downloaded a Cura plugin called X/Y/Z Shift to allow me to offset the X by 15mm to compensate.
I realized that was giving me problems and disabled it. I also changed my bed settings back to full size.
After restarting Cura at some point, the X/Y/Z shift plugin (which I'd edited to change the default to be x=15mm) was enabled again and I didn't notice. I've just disabled it and printed successfully.
- Heated bed
JonS
Postby teicher » 2015-Jan-Sat-21-Jan
I've pinged them before about cura settings and providing a suggested started profile, but now that they are recommending the tool its even more important they do so.
The included machine profile settings for printrbots in cura (at least all of the versions I've used, 14.x on Linux) all have bad settings. Not only is the start/end gcode no good for auto leveling, the retraction and hot end tip settings are very wrong. They are a ticking support case & replacement parts time bomb IMO.
I'd open a support ticket for the kapton tape, they should be able to help you with that. The bed scrape might be ok, I'm not there to see it. You could always ask I guess. I have some very small scratches on my current mic6 bed, but I had to replace my first mic6 after it got gouged by the tip and left with deep scars that couldn't be hidden with 2x layers of tape.
teicher
Postby JonS » 2015-Jan-Sat-23-Jan
The bed is probably okay, once tape is applied. I'll have to keep an eye on it.
The Pronterface UI report echo's the following:
< Bed x: 10 y: 259.00 z: 1.00
< Bed x: 10 y: 10 z: 1.03
< Bed x: 210.00 y: 10 z: 3.54
Unless there's something cryptic in those numbers, it says that I have 2.5mm on bed tilt in the x axis. While autolevel and a single extruder may be able to cope with that, it won't work on a dual-extruder set up. I can already when printing small calibration structures that my (currently) unused extruder is rubbing on the bed tape (and I've even had it tear the tape) while the other extruder is printing okay.
How does one even level the bed on this machine?
- Heated bed
JonS
Postby Sablebadger » 2015-Jan-Sun-02-Jan
I've run into a similar problem to your last post, albeit a much smaller tilt. The second extruder tip is rubbing along the already printed material, and sometimes knocks it loose or makes the print skip.
I just watched a print go awry on this, then I read your post and it all clicks. bed leveling works great with a SINGLE point. If you have a wide base (two extruder tips) to worry about then things are a bit more problematic.
On Google+ someone made a comment to my complaint saying:
"Since the printer has dual z axis did you check to see that the x carriage is level across. One side may be a little lower causing the second hot end to drag or catch. " I don't even know how to do that. But it might be something to look into.
badger
Sablebadger
Postby musk » 2015-Jan-Sun-02-Jan
musk
Postby JonS » 2015-Jan-Sun-06-Jan
Printrbot support helped me sort out the problem.
My X carriage was tilted. I had to manually turn the right leadscrew to level it and then run G29 to check the tilt. After a few iterations, it very level.
I'm impressed that I got a response from their European support on a Sunday.
- Heated bed
JonS
Postby DonaldJ » 2015-Jan-Sun-11-Jan
DonaldJ
Postby Sablebadger » 2015-Jan-Tue-17-Jan
Last night I was able to get a near perfect print with one extruder by tweaking the Z axis threaded rods.
Here is how I did it:
Up Z to 1/4 from the bottom
move extruders to the left to create a clear area on the middle bar
lay a small bubble level on the flat bar so you can see when the level changes. (I didn't care if it was level, just that it changed).
twist the left threaded rod (facing the machine) slightly by hand. I didn't need to hold the right one in place, just twisting the left seemed to work.
watch the bubble level to see if the angle changes.
Print a wide flat thing and watch the surface of the print. ( i was printing this http://www.thingiverse.com/thing:178862)
If you see "smushing" or extra gunk or dragging of the nozzle through already printed area, then adjust again (1/4 turn increments if it's really close) until you get a smooth print.
I got this to print last night using this method.
http://www.thingiverse.com/make:113566
badger
Sablebadger
Postby musk » 2015-Jan-Tue-19-Jan
Brook made a useful video showing how to level the GO machine, fully applies to the Plus.
musk
Postby paul314 » 2015-Jan-Thu-14-Jan
Grr. What is everyone else's experience with the default profile built into Cura? Repetier was crashing on me, so I just tried to print something with Cura. Ripped the living daylights out of the Kapton. I started printing, my machine did its homing routine nicely, printed the outline for the bottom layer and then started doing its darnedest to drive the nozzle through the bed. Lifted up, did the same in a couple other places before I came to my senses and stopped the print. (Oh, and since Cura doesn't have any manual controls that I can find, left the nozzle hot and pressed against the aluminum until I quit, fired up repetier and got to manual control.)
Slic3r complained that the model I was trying to print was nonmanifold, but that doesn't seem like a reason to go all engravey. (And Cura didn't complain at all.)
Are there settings I should use for Cura other than the ones it has already? Should I just go back to repetier and handle it with kid gloves? Oy. At least the aluminum seems OK.
(I've added some insulation to the bottom of the bed, but that doesn't seem relevant here because a) G29 reported it as even more level than before and b) even on this print the machine laid out one perfect perimeter before going for a dive.)
paul314
Postby musk » 2015-Jan-Thu-17-Jan
If only one of two nozzles is digging into the Kapton tape, that means the nozzles are not at the same height. This could be caused by a skewed gantry which needs to be leveled using Brook's video linked above. Alternatively, the nozzles are possibly mounted at the different heights in the aluextruders. Gantry alignment is the first thing to check.
musk
Postby paul314 » 2015-Jan-Fri-14-Jan
Thanks! It turns out I had stupidly thought that I had tightened the nozzle all the way when I reassembled after clearing a jam. I was clearly off by half a millimeter or so. Changed the Z offset for now, but when I go to print with both extruders I'll have to get them matched. (They were matched before when I did test extrusions with both of them.)
paul314
Postby teicher » 2015-Jan-Fri-22-Jan
teicher
Postby paul314 » 2015-Jan-Fri-22-Jan
paul314
