Printrbot Talk Forum • View topic - Enquiry about Stock Levels?
Postby andy6a6 » 2014-Dec-Thu-12-Dec
Any idea when you'll have individual Simple Metal YZ bearing blocks available? Having bearing issues ( viewtopic.php?f=15&t=8824 )
andy6a6
Re: Enquiry about Stock Levels?
Postby Shaun.s » 2014-Dec-Thu-13-Dec
the help section on printrbot's site is probably going to be your best bet. i don't think this board is affiliated with printrbot the company... only an enthusiast forum.
Shaun.s
Postby RetireeJay » 2014-Dec-Thu-13-Dec
You're both right. This is an enthusiast forum not run by Printrbot. But in the era before Printrbot started its own support forum, they did promise to look in on the "PBHQ Official Forum - Genera" topic. I think they still do from time to time.
Postby David@Printrbot » 2014-Dec-Sun-16-Dec
Printrbot: Dominate Your Prints!
David@Printrbot
PBHQ Official
