Printrbot Talk Forum • View topic - Cartidge-type Ubis discontinued?
Postby DonaldJ » 2014-Oct-Fri-15-Oct
Got a replacement for my 1.75mm Ubis hotend (cartridge-type) and it's like the original nichrome/ceramic units, but not 3mm. Any reason for returning to the original style?
I'm asking because, over time, the cartridge-type slowly petered out. There was increased resistance as the filament fed, which led to the dreaded clicking extruder motor. My best efforts to clean the interior were to no avail. Also, as I peered down the barrel of the hotend, I could see 2 discrete "steps" where different materials were mating. Shouldn't it have been one continuous smooth path?
DonaldJ
Re: Cartidge-type Ubis discontinued?
Postby orangefurball » 2014-Oct-Fri-17-Oct
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby Munson » 2014-Oct-Fri-18-Oct
I would like to say this,if Printrbot sold the old style Ubis or ubis parts I would purchase them instead of buying a ripoff hotend,but I had no choice and purchased the Anubis.
I have used it for over a month now and I have to admit it is just as good as the original.
Munson
Postby thawkins » 2014-Oct-Fri-18-Oct
Postby orangefurball » 2014-Oct-Fri-21-Oct
orangefurball
Laser scintillater
Postby RetireeJay » 2014-Oct-Sat-07-Oct
The connector and the switching transistor (MOSFET) used on the Printrboard for the Hot End are identical to the ones used for the Heated Bed, which typically draws more than 100 watts - so there's no problem with using a 40 or 50 watt cartridge on your Hot End. But if you go over 36 watts, I'd recommend using all four pins on the connector. Do this the same way they do for the Heated Bed: the left-hand pair of pins gets wired together, and the right-hand pair of pins gets wired together.
Postby Munson » 2014-Oct-Sat-07-Oct
Orangefurball,I am using the 40w on my printrboard.I am also using an atx and my heat bed is on a relay so I really don't have much of an extra load on the board.
Munson
Postby Mooselake » 2014-Oct-Sat-14-Oct
The 40W cartridges can cause more problems if the thermistor (or anything else involved in temperature control, like a shorted mosfet) fails the wrong way and causes them to be continuously powered, compared to the 30 watters. In both cases you need to keep your firehose, or other fire suppression device, handy. Other than the obvious power ratio I don't know what the increased risk is, but the results can require a change of residence, or worse. Doesn't mean you need to avoid them, but you should be aware there's an increased risk.
Disclaimer: I'm a medical first responder with a volunteer fire department, and a rural paramedic, so I worry about this stuff...
Complements of wikipedia
Postby orangefurball » 2014-Oct-Sat-14-Oct
orangefurball
Laser scintillater
Postby Munson » 2014-Oct-Sat-14-Oct
So is there a way of placing a fail safe like a inline fuse?
Munson
Postby Mooselake » 2014-Oct-Mon-15-Oct
You'd need a thermal fuse attached to the hot end. The extruder can be within it's current spec and still get very hot, so a current sensitive fuse wouldn't help. There was some discussion a while back about extruder induced fires that talked about them - one of the problems is that it needs to be a higher temp than the typical coffee maker thermal fuse, and the higher temperature's hard to find. If you find a good source post it.
I'm a first responder with a rural fire volunteer fire department, and recently semi-retired from being a full time paramedic. I've seen what fires can do to you; it's not pretty. This doesn't mean you should think about giving up your printer (cold dead hands...) but you should be aware of the potential danger, and take some preventative steps. Either watch your printer, or think about some kind of fire prevention or suppression.
Postby thawkins » 2014-Oct-Mon-20-Oct
Postby Mooselake » 2014-Oct-Tue-11-Oct
Not so .
Postby orangefurball » 2014-Oct-Tue-13-Oct
orangefurball
Laser scintillater
Postby Munson » 2014-Oct-Wed-05-Oct
Why is there no fail safe on the printrboard and Ramps if there is a slight chance of fire?
Munson
Postby Mooselake » 2014-Oct-Wed-10-Oct
That's a good question. I can only guess. Perhaps it's one of those as soon as you take precautions you'll get massive lawsuits if the protective device fails? I don't know why Makerbot dropped their thermal fuse, but they never caught on with anybody else.
They're use at your own risk hobby devices. While ianal I'd guess that there isn't any official mandate to conform to UL, CSA, or some other alphabet agency. To be honest I mostly hope they don't - I don't want to get a device with a 40 page manual detailing all the ways you shouldn't use your printer ("Do not put mouth directly under nozzle while operating and inhale as this may cause harmful or fatal injuries from fumes or molten plastic". "Digital calipers are a recommended tool, Do not run with them or you may be impaled by the extended depth gauge." etc.) and that's inoperative because somebody might want to drink from the extruder and there's something to prevent it.
Get a smoke detector and fire extinguisher. You have one anyway, right? Your toaster may fail and set your bagel on fire. Don't leave home with the printer running (puts a damper on those 40 hour prints...) or at least put them somewhere where a meltdown won't cause a disaster. Basic common sense once you're aware there's a small chance of a failure.
One of my neighbors was on the board of my local mutual insurance company. Some 30 years ago said their biggest fire hazard was coffee makers (I'm guessing he skipped over wood stoves...). I'm not giving up mine.
Postby thawkins » 2014-Oct-Wed-11-Oct
Postby DonaldJ » 2014-Oct-Fri-23-Oct
Many thanks for all of the replies, but none of them address the original question of the discontinuation of the cartridge Ubis.
Which is now a moot point. Brook Drumm just posted some bits on the Twitter feed about two new products, one of which is an all-metal Ubis hotend, good to 300C.
Very nice.
DonaldJ
Postby orangefurball » 2014-Nov-Sat-01-Nov
orangefurball
Laser scintillater
Postby Munson » 2014-Nov-Sat-05-Nov
The new extruder looks like a E3D with a Printrbot signature red boot on it.
Munson
Postby orangefurball » 2014-Nov-Sat-14-Nov
orangefurball
Laser scintillater
Postby rigarashi » 2015-Aug-Sun-00-Aug
rigarashi
Postby RetireeJay » 2015-Aug-Sun-05-Aug
Sorry, rigarashi, I must correct you. the thermistors used here are Negative Temperature Coefficient. High resistance = low temperature; Low resistance = high temperature. Open circuit means low-temperature fault; short circuit mean high-temperature fault.
That said, you are correct that a failure of the firmware or the hardware on the Printrboard can lead to an uncontrolled amount of heat going to the heater(s). And if you really want to be safe, yes you should use other means to detect and deal with that problem. Maybe smoke detector, maybe bimetallic temperature switch, etc. All of the "old timers" on this forum strongly recommend never leaving the printer running for a long time while totally unattended (like if you leave the premises for hours at a time or go to sleep). Personally, I never leave the printer running for more than 30 minutes or so without actually going to look at it, and I'm usually inside the house for just about the whole time. Lots of people have cameras set up so they can check on their smartphone.
BTW, the firmware is called "Marlin" not "Merlin"
Postby rigarashi » 2015-Aug-Sun-07-Aug
Thank you for correcting me, RetireeJay on two counts... and while we're on the subject of thermistor, I meant to ask... if the heater is turned off, the thermistor will naturally read the ambient temperature of the bed, for example, assuming it has not been heated. If the thermistor is open (thus low temperature approaching zero?) would the firmware still detect this open circuit and trigger an error? In other words, would turning the heater off basically also turn off error detection and triggering?
rigarashi
Postby thawkins » 2015-Aug-Sun-09-Aug
Postby frankv » 2015-Aug-Sun-13-Aug
Also, check that the heatsinks of the heater & heat-bed power transistors aren't touching. If they are touching, you may get uncontrolled heating.
