Extra connectors on power jumper-SBlack Heated Bed
The PBHQ Official Forum should only be used for questions/issues/topics that only PBHQ can answer (eg. order issues, missing parts from your order, any messages directed specifically at PBHQ people, etc). All other questions/issues/topics should be posted in the regular forums.
Postby temichaels » 2014-Oct-Tue-13-Oct
I just received the heated bed kit for a simple metal black printer. I am confused about the following: There is a 4 pin to 4 pin power supply jumper, yellow & black to red & black, which I understand. However; on that same jumper there are 2 ea 3 pin connectors (molex type) that don't appear to have mates to connect to on my version D board. Can you help on this.
PS. Are PB heated bed installation instructions available for the simple metal black.
temichaels
Re: Extra connectors on power jumper-SBlack Heated Bed
Postby EddB » 2014-Oct-Wed-16-Oct
Two rows of 3-pin connectors. Sound like you got the upgrade for a Rev. F. Printrboard and you needed the one for the revision D printrboard.
Click on the F board and you will see that it has 2 rows of 3 pins for the atx power input.
http://printrbot.com/shop/simple-metal-heated-bed/
If that's the case, printrbot will probably replace the cable with no problems.
Ed
EddB
Postby David@Printrbot » 2014-Oct-Thu-00-Oct
If needed, you can open a support ticket here... https://printrbot.zendesk.com/hc/en-us/requests/new
Printrbot: Dominate Your Prints!
David@Printrbot
PBHQ Official
