Printrbot Talk Forum • View topic - Improved Alu Extruder Availability?
Postby JonS » 2014-May-Thu-11-May
At Bay Area Maker Faire I was told that there's an improved alu extruder in the works, that reduces the gap between the drive gear and the bottom feed hole to help when printing with flexible materials.
As someone who sometimes prints using flexible filaments, this mod is important to me. When will it be available, and how will I be able to make sure I get that version when I order?
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Re: Improved Alu Extruder Availability?
Postby bleeps » 2014-May-Thu-17-May
bleeps
Postby JonS » 2014-May-Thu-17-May
- Heated bed
JonS
Postby MegaMoonMan » 2014-May-Fri-10-May
Hopefully there will be an option to upgrade all existing aluminum extruders with a new part, rather than making everybody buy a whole new extruder.
MegaMoonMan
