Printrbot Talk Forum • View topic - Project Elsa i9
Project Elsa i9
Project Elsa i9
Postby REPRAP SQUAD » 2013-Apr-Sun-12-Apr
So the guys at RepRap Squad have decided to take on the Mendel 90 hybrid build as a side project as if we do not have enough projects going on. We are not going to build a standard Mendel 90 however. We originally couldn't decide between the Prusa I3 and the mendel 90. So we figured why not have our cake and eat it to. So after looking at plans for both designs we realized how similar they really are. We liked the I3 for some parts and the M90 for others. So we are going to take the best from each design and integrate them together while adding in a little of our own tricks as well. I will be updating as we go. So far the parts that are decided are the frame, z-motor mounts and top rod mounts. We are going to use the Mendal 90 frame with a few small adjustments. The I3 Z-axis motor mounts will be used as well as a variation the I3′s Z-axis top rod mounts. Here's some pictures of the build so far---»
** This will not be how the final version looks. This is just the mock-up phase so we can get all the designs perfect. The final version will more than likely be build using dibond, aluminum alloys and carbon fiber.**
Here's the start of the main frame. Many changes will be made the to make it the best it can be for this design. We moved the rear supports inward so that it lines up with the inner frame. This gives up a lot more room for wiring and electronics.
http://reprapsquad.files.wordpress.com/ ... 174817.jpg
In this picture you can see the fan and duct setup for the filter system. It will pull in air from the print bed and filter it. Its also setup so it can be hooked up to our ventilation system.
http://reprapsquad.files.wordpress.com/ ... r-duct.jpg
http://reprapsquad.files.wordpress.com/ ... -close.jpg
Here's a top down view, you can see we decided to use a 203w Xbox power supply.
http://reprapsquad.files.wordpress.com/ ... 142908.jpg
In this picture you can see the z-axis extension add-on and the changes made to date.
http://reprapsquad.files.wordpress.com/ ... ension.jpg
http://reprapsquad.files.wordpress.com/ ... 180838.jpg
Project Elsa i9
Re: Project Elsa i9
Postby REPRAP SQUAD » 2013-Apr-Sun-16-Apr
Return to Showcase
