Printrbot Talk Forum • View topic - Accessory: the color change clip
Postby Joymaker » 2015-Mar-Tue-00-Mar
Ever get tired of holding down that stiff spring while doing a color change or otherwise manipulating filament? I offer to the Printrbot world – the Simple Metal color change clip.
Press down, insert this around the screw, let go… you're hands-free as long as you need to work with the filament. Pull it out when you're done. (Navy blue, near center of photo)
http://www.thingiverse.com/thing:706303
Joymaker
Re: Accessory: the color change clip
Postby Jamie_K » 2015-Mar-Sun-20-Mar
I love it!
After seeing it, it seems "obvious" but of course I never thought to do something like that.
Well done.
Jamie_K
Postby jolars » 2015-Mar-Mon-15-Mar
It needs a little handle up front for inserting and removing it easily.
jolars
Return to Showcase
