My Simple(s)
My Simple(s)
Postby MartyS » 2014-Jul-Wed-10-Jul
Well I'm hooked, got a 1401 kit about a month ago and have already bought a Simple Metal and ordered the 1405 upgrade kit for the 1401.
Been using mostly FreeCAD to design stuff, and Cura to slice and generate Gcode.
MartyS
My Simple(s)
Re: My Simple(s)
Postby Defy » 2014-Jul-Wed-20-Jul
soon you'll have an army!
Defy
Re: My Simple(s)
Postby MartyS » 2014-Jul-Fri-00-Jul
Just finished rebuilding my 1401 with the 1405 upgrade kit. I also ordered 10 inch rods and extra belt, cut some 1/8" thick aluminum to make a wide bed.
Printable area is X180 Y100 Z120
I was worried I was too rough with the aluminum and warped it, I'll have to print a really big rectangle to know for sure, the 5mm calibration steps printed out fine.
MartyS
Re: My Simple(s)
Postby bck » 2014-Jul-Sun-14-Jul
MartyS, what are your parts for bowden there?
bck
Re: My Simple(s)
Postby MartyS » 2014-Jul-Sun-15-Jul
I'm not using a bowden extruder, those are just tubes to feed the filament without tipping over the spool holder or the printer.
Edit: I should say "guide the filament" the extruder is pulling the filament thorough the tubes.
Looks like I didn't warp the bed when cutting and drilling, it's been working fine.
2 printers working away....
MartyS
Re: My Simple(s)
Postby MartyS » 2014-Jul-Tue-22-Jul
Made new bed holders, mostly just to practice with using FreeCAD to make something more complex than I've been doing so far.
Belt tensioner is one from the many X upgrades released by others.
MartyS
Re: My Simple(s)
Postby spitfirehauser » 2014-Jul-Wed-13-Jul
MartyS Great Mod, i really like the new X ends. any chance i can the raw scad file so i can modify it for the 2014 simple. thanks
Steve Hauser
Modified Simple 2014 kit
spitfirehauser
Re: My Simple(s)
Postby MartyS » 2014-Jul-Wed-18-Jul
FreeCAD 0.14 crashes when I try to export the designs to .scad format.
Here's a zip file with the 2 FreeCAD .FCStd files.
MartyS
Re: My Simple(s)
Postby spitfirehauser » 2014-Jul-Thu-14-Jul
cool thanks for the files i will work to get the 8mm slots moved in to work on the original spacing
Steve Hauser
spitfirehauser
Return to Showcase
