Fishing line stability and resistance
Postby hcrepin » 2013-Dec-Mon-18-Dec
Actually I encounter a little problem, I broke my Y fishing line and searching a correct replacement, but, anyway, seems not very stable mounting for movment.
Anybody a suggestion for a replacement or maybe decreasing print speed?
hcrepin
Re: Fishing line stability and resistance
Postby hcrepin » 2014-Jan-Wed-06-Jan
Finally, I found the solution: replace the original wires by polyamide 1 mm lines but with longer lines that I shorten by twisting them around 40 times:
Well, sorry, site disallow me to post the pictures ...
hcrepin
Postby thawkins » 2014-Jan-Wed-06-Jan
hcrepin wrote:Finally, I found the solution: replace the original wires by polyamide 1 mm lines but with longer lines that I shorten by twisting them around 40 times:
I belive the original line is this.
http://www.amazon.com/gp/product/B0084O ... UTF8&psc=1
Postby RetireeJay » 2014-Jan-Wed-10-Jan
Even newbies can post pictures. Use the "Upload Attachment" tab below the editing screen, then browse to find the picture on your computer. Upload, and then "Insert Inline"
Postby hcrepin » 2014-Jan-Thu-16-Jan
Thanks, here is the picture
hcrepin
Postby hcrepin » 2014-Jan-Thu-17-Jan
Possible but strange that mine broke so easily.
hcrepin
Postby thawkins » 2014-Jan-Thu-22-Jan
If your carriage (x or y) keeps hitting the ends of its travel, or your line is loose, it will result in the sandpaper drum spinning against the line, which will fray it and it will break.
Postby hcrepin » 2014-Feb-Sun-06-Feb
Effectively that's one of the problem, weird because, I've tuned the stop-end to avoid continue travel but nothing to stop the plate travel or maybe better configure the repetieter host configuration to work with less shocks.
hcrepin
Postby thawkins » 2014-Feb-Sun-09-Feb
hcrepin wrote:Effectively that's one of the problem, weird because, I've tuned the stop-end to avoid continue travel but nothing to stop the plate travel or maybe better configure the repetieter host configuration to work with less shocks.
From the photo, it looks like the line is wound wrong, starting from the left, you should run to the top of the drum, then around 3 times and back out to the tensioner on the right hand side. If it goes in the wrong direction after that, you should rotate the motor connector on the board.
Double check the endstops. You can use the m119 command sent in manual commands to show the status of the endstop switches. It should show a different status when the carruage is pushed back into the home position.
The way you have it the angle of the line from the screw holding the end of the line to the bottom of the drum is too steep, and it will create a considersble push back at the ends of travel in each direction, which may explain why your endstop is not working.
Postby RetireeJay » 2014-Feb-Sun-10-Feb
Remember, the so-called "endstops" are not really endstops. They are used ONLY during a homing maneuver. At all other times the firmware on the Printrboard IGNORES the endstops.
Return to Showcase
