Printrbot Talk Forum • View topic - Fishing line stability and resistance
Postby hcrepin » 2013-Dec-Mon-18-Dec
Actually I encounter a little problem, I broke my Y fishing line and searching a correct replacement, but, anyway, seems not very stable mounting for movment.
Anybody a suggestion for a replacement or maybe decreasing print speed?
hcrepin
Re: Fishing line stability and resistance
Postby hcrepin » 2014-Jan-Wed-06-Jan
Finally, I found the solution: replace the original wires by polyamide 1 mm lines but with longer lines that I shorten by twisting them around 40 times:
Well, sorry, site disallow me to post the pictures ...
hcrepin
Postby thawkins » 2014-Jan-Wed-06-Jan
Postby RetireeJay » 2014-Jan-Wed-10-Jan
Even newbies can post pictures. Use the "Upload Attachment" tab below the editing screen, then browse to find the picture on your computer. Upload, and then "Insert Inline"
Postby hcrepin » 2014-Jan-Thu-16-Jan
Thanks, here is the picture
hcrepin
Postby hcrepin » 2014-Jan-Thu-17-Jan
hcrepin
Postby thawkins » 2014-Jan-Thu-22-Jan
Postby hcrepin » 2014-Feb-Sun-06-Feb
Effectively that's one of the problem, weird because, I've tuned the stop-end to avoid continue travel but nothing to stop the plate travel or maybe better configure the repetieter host configuration to work with less shocks.
hcrepin
Postby thawkins » 2014-Feb-Sun-09-Feb
Postby RetireeJay » 2014-Feb-Sun-10-Feb
Remember, the so-called "endstops" are not really endstops. They are used ONLY during a homing maneuver. At all other times the firmware on the Printrboard IGNORES the endstops.
Return to Showcase
