Total Y axis upgrade
Postby plexus » 2013-Dec-Sat-00-Dec
Linear rail with sintered bronze flat bushings. 6016 3.1mm aluminum platen. MIC6 6.3mm heatbed machined flat. silicone bed heater. still using the GT belt. much more precise! i will do X and Z at a later date.
Re: Total Y axis upgrade
Postby allanonmage » 2013-Dec-Mon-15-Dec
TOTALLY BADASS
What material did you make the bed out of? Did you make or order the aluminum print surface?
What is that steel looking beam underneath and how does it work?
allanonmage
Layer 100 of 1234
Postby plexus » 2013-Dec-Fri-20-Dec
The only Y axis was removed. I had been using GT2 which were carried over to the upgrade. I replaced the large 36T pulley with a smaller one. I was thinking I need more torque than speed with the heavier materials. jury is still out on that - i will try running the 36T and see if it works. more on is later...
The new Y is built on a PCB linear rail, low profile: http://www.pbclinear.com/UGA-Low-Profil ... near-Slide This rides on "frelon" bushings which are probably some kind of maintenance free teflon bronze bushing. maybe. they run smooth with little play. this was bolted to the base through the top. the platen is 6061, 3.18mm that i measured and drilled to sit on the rail car at its centre of gravity with the bed installed.
The bed is custom made 6.35mm MIC6 by heathyfatboy and his father. i am unsure if the guy is actually fat, but he does make a healthy print bed. the bed is machined flat on the top. on the bottom i had a channel routed out that will accept a 100k glass thermistor and a calibrated platinum temp sensor. the intention is to run the platinum sensor to a calibrated digital thermometer for more precise bed temp reading. i havent done the temp sensor work yet.
I am heating the bed with a QU-BD silicone heater. this heater rocks and get the bed to 75C in about 5 minutes. the bed is sitting on 5 springs with brass bolts and thumbscrews on the corners for leveling adjustment. I replaced the original Kickstarter PB+ motor with a kysen motor. it runs smoother and cooler.
I reused the belt clips I has on the original platen. I had to print. part to hold a bolt for the Y stop, no big problem.
So this upgrade has worked well. the prints turn out much better. My aim is to increase the speed and quality of the PB into the realm of printers in excess of $3000. this Y upgraded cost $250 in parts. It has improved the print quality where the consistency of the extrusion is more consistent. as you would imagine this is Y has very little play and so this imparts better quality in that regard. i will post pics soon.
I plan to do X the same way but I will have to design and print parts to hold the components. i will switch to PBC frelon bushings instead of linear bearings. i will retain the X motor and belt drive. i plan to replace the extruder with a direct drive PB aluminum extruder. I also will experiment with the all metal magma hotend. For Z the upgrade is to 10mm leadscrews and delrin nuts. all motors will be kysan.
the total cost will be around $600. so you are talking about $1600 for a printer that i think will equal or exceed anything in the $2000-4000 range.
Postby Munson » 2014-Sep-Mon-08-Sep
Is there a lag in retraction on your x axis due to the extra weight of the plate?
Munson
Postby plexus » 2014-Sep-Mon-11-Sep
Munson wrote:Is there a lag in retraction on your x axis due to the extra weight of the plate?
The plate is the Y axis. no issues. prints great.
Return to Showcase
