Enclosure for Unheated Spaces
Postby schlem » 2013-Mar-Tue-22-Mar
Hi
I got banished to a sad, cold garage, so I made an enclosure to keep the Schlabricator warm.
Here's a link to an Instructable I created: [unable to post link thanks to sp@m filter]
And here's where you can download the gizmacci I created to hold it all together: [unable to post link thanks to sp@m filter]
I've found that it has greatly improved the quality of my prints, and it heats up faster too!
So, either search Instructables for "3D Printer Enclosure"
And Search Thingiverse for 55065
Or contact me directly for the links.
Better yet, if someone wanted to post the links on my non-spamming behalf, that would be great.
Hope this helps someone
schlem
schlem
Re: Enclosure for Unheated Spaces
Postby drawcut » 2013-Mar-Wed-19-Mar
drawcut
Postby RetireeJay » 2013-Mar-Wed-19-Mar
Were you banished because of the smell of ABS?
I moved my 'bot in from the garage when I switched to nylon. It has its challenges, for sure, but smell is not one of them (search these forums for nylon for lots of ideas and debate).
Postby schlem » 2013-Mar-Thu-00-Mar
Thanks for posting the links!
schlem
Yes, the wife is sensitive and has a few theories about the toxicity of ABS fumes, and, discretion being the better part of valor, I moved it out of the house. In hindsight, I could have put an intermittent (arduino or similar) fan on the enclosure and maintained a negative pressure and vented it outside. Besides, outside, I can listen to whatever Pandora station I want, at whatever volume. Small things...
schlem
Postby rsilvers » 2013-Apr-Mon-19-Apr
The cheapest way is to use a large box - like the one my laser printer came in, and put a window on it.
rsilvers
Postby Mooselake » 2013-Apr-Tue-01-Apr
That is a well written and entertaining build description. An inspiration to visit Home Depot on the 1100 mile round trip to the kid's graduation.
Postby REPRAP SQUAD » 2013-Apr-Fri-10-Apr
I've been debating building a case for my oversized printrbot. I might take this as an opportunity to do so. Thanks for the post.
http://www.enviousmods.com
Return to Showcase
