The face behind printrbottalk.com
Postby plexus » 2013-Mar-Mon-01-Mar
messing around tonight with the PB+ and my camera...
Re: The face behind printrbottalk.com
Postby Extrude3D » 2013-Mar-Sat-06-Mar
Plexus, you look like a guy in the 90's silicon valley working on making a tech startup before the dotcom bubble :D
3dpaftermarket
Extrude3D
Postby plexus » 2013-Mar-Sat-09-Mar
What? I thought it was still 1991.
Postby DonaldJ » 2013-Mar-Sat-14-Mar
plexus wrote:What? I thought it was still 1991.
No, it's 1967.
DonaldJ
Postby gyronictonic » 2013-Mar-Sat-19-Mar
Is that you Dr. Nicholas Rush?
Backer # 626
Printbot Plus
Upgrades
- GT2, 36 teeth timing pulley
- Acme rods
- .25mm nozzle
- Drawcut's Spur gears for the Wade Extruder
gyronictonic
Postby Extrude3D » 2013-Mar-Sat-20-Mar
No, it's 1967.
1967 and we are using the bleeding edge plastic extrusion technologies powered by portable computers!
3dpaftermarket
Extrude3D
Postby Guyverblue » 2013-Mar-Sat-20-Mar
Extrude3D wrote:
No, it's 1967.
Temporal anomalies?
Printrbot Jr
OB 1.4
Prusa I3
Fredericktown, Missouri - USA
Guyverblue
Postby mrsamnc » 2013-Jul-Tue-12-Jul
So who's that in your avatar image? That self portrait absolutely rocks by the way! Great framing, composure and depth to the image!
Printrbot Jr. - July 2013 Model | Heated Bed | Brass M8 Rod | GT2 Pulley/Belt | Tool Less Belt Tensioners - by Mochaboy | Jr. Printr Cup
My Build/Mod Log
mrsamnc
Postby allanonmage » 2013-Dec-Mon-15-Dec
You look much less than The Wondrous Wizard of Oz that your avatar implies.
Started with a Printrbot LC Kit; now it's a monster as big as a mid size fridge!
Single ATX Power supply, 650 watts, relay controlled heat bed
extra Z height (3+ ft) via longer rods, but I don't use it. Yet. To reduce wobble, I'm using thing:46082 under the Printrbot.
Dual heated beds, 1 currently working; space for a 3rd
Purple gluestick on glass seems to be sticky enough to get adhesion
FB album with pics: https://www.facebook.com/media/set/?set ... ec287e8726
This was supposed to be a tool, not a series of projects... grrrrr......
allanonmage
Layer 100 of 1234
Postby pomonabill221 » 2014-Feb-Sat-16-Feb
WOW, and actual nerd-a-riffic!
PBplus V2 kit.
* NOW with AUTOLEVEL!!!!
pomonabill221
Postby RetireeJay » 2014-Feb-Sat-16-Feb
Who is proud to shave with a 100 year old straight razor. ;)
Postby marmil » 2014-Feb-Mon-19-Feb
RetireeJay wrote:Who is proud to shave with a 100 year old straight razor. ;)
I was impressed! And not even using a mirror either. :)
CG & 3D enthusiast • Printrbot+ Kickstarter backer • Mods: GT2 belts, custom aluminum y-carriage and print bed
marmil
Postby plexus » 2014-Feb-Mon-20-Feb
Mirror-schmirror. and I strop on my hand and leg. :P
Return to Showcase
