Status LED's Finished
Postby mikemwa53 » 2013-Jan-Wed-03-Jan
I got my Status LED's for my Plus finished. Thanks for the help. It turned out OK. There are 7 LED's. Left to right.
http://www.youtube.com/watch?v=HmBnnIqyjKw
Turn your volume down!
1. Power
2. Fan
3. Extruder(Hot End)
4. Heated bed
5. X motor
6. Y motor
7. Z motor
Sorry for the blurry video.
Sooooo much to do
Sooooo Little time!!!
Montgomery, IL. USA
mikemwa53
Re: Status LED's Finished
Postby scantrontb » 2013-Jan-Wed-23-Jan
mikemwa53 wrote:1. Power
2. Fan
3. Extruder
4. Heated bed
5. X motor
6. Y motor
7. Z motor
is the #3 light your extruder MOTOR, or your extruder/nozzle heater? due to how it is flashing so rapidly, I'm thinking it is the motor... it looks like for completeness sake, you'll want to add an EIGHTH LED to the ones you have already, that one being the one you don't have: the nozzle heater (or motor, whichever is the one not shown earlier)
PB+ #786
scantrontb
Can update firmware
Postby mikemwa53 » 2013-Jan-Thu-00-Jan
#3 is the hot end. Edited that. It flashes at different rates depending how close it is to the set temperature.
AAAHHH!! The extruder motor. Forgot about that one. CRS must be slipping in. Good catch. Project for tomorrow. Back to the old drawing board. Will post the new one when I get it finished.
Sooooo much to do
Montgomery, IL. USA
mikemwa53
Postby Rob311 » 2013-Jan-Mon-10-Jan
How did you connect it to the system?
Rob311
Postby mikemwa53 » 2013-Jan-Tue-22-Jan
Rob311. See this post for most of the information.
viewtopic.php?f=21&t=2163
As for the wires you will need very thin ones, maybe ribbon cable. For right now I just stripped about 1/4 inch of insulation from them and twisted the ends. I stuck the wire into the appropriate pin in the connector and used a little hot glue to keep them in place. You could also use tape. On the stepper motor connector it doesn't really matter which pin you attach it to. I haven't figured out a better way to do it yet.
Sooooo much to do
Montgomery, IL. USA
mikemwa53
Return to Showcase
